Old 11-22-2022, 06:25 PM   #1
Cartel
Cartel's Avatar
Drives: 2007 Yaris Hatch is sold
Exclamation Yaris sedan loud "thud" on hard cornering
This is a 2008 yaris sedan and when I make a really hard left turn at speed, I hear a loud thud noise like someone hitting the inner wheelwell with a heavy hammer on the right.
anyone ever have that?
thanks
Cartel is offline   Reply With Quote
Old 11-22-2022, 06:45 PM   #2
Ecefour
I have the same exact problem. I believe it’s an outer tie rod end. I’ll report back when I get my parts in the mail.
Ecefour is offline   Reply With Quote
Old 11-23-2022, 07:13 AM   #3
ex-x-fire
Cv axle too.
Old 11-23-2022, 07:27 AM   #4
Cartel
Cartel's Avatar
ya I dont think its the tierod I dont feel anything in the wheel. and the cv isnt clinking.
It sounds like someone throwing a softball at the front fender.
I guess I'll have to pull the wheel and start prying
Old 11-23-2022, 08:18 AM   #5
bronsin
bronsin's Avatar
How many miles on your Yaris? In my experience noises like that under those conditions can be caused by bad ball joints. You seldom see that problem Onlyon cars with high mileage
Old 11-23-2022, 01:17 PM   #6
sh0rtlife
wife did a hard uturn in traffic and bumped the curb and ive got the same noise, ive had the wheels off and cant find anything..ive done the shimmy n shove tests i used to do at teh tire shop checking for bad suspension parts and came up empty...strut tower mount?
mine is exceptionaly hard to replicate..every now n then a steep drop speedbump in a slight turn or the perfect dip in a full lock corner will replicate it
Old 11-23-2022, 09:33 PM   #7
remcafee
check your lower control arm bolts, sometimes they will break off
Old 11-23-2022, 09:34 PM   #8
remcafee
theres a tsb for updated bolts
Old 11-26-2022, 12:18 AM   #9
CrimsonEclipse
Drives: .
The rear suspension can make a loud pop when I turn off a road to a parking lot and there is that relatively sharp bump for water drain control
I can easily sound like it is coming from the front.
CrimsonEclipse is offline   Reply With Quote
Old 11-26-2022, 03:40 PM   #10
sh0rtlife
i know on mine atleast the "pop" sounds like that of a 1/2 inch ratchet handle and the impact point sounds like its coming from..well..the battery....
fully away of sound getting carried and shifted around cars, so i suspect its something in the left front but all of my initial inspections have turned up nothing
new snow wheels will be going on soon so ill do a full inspect of the rear
Toyota ending Yaris Hatch & Sedan production for United States by end of June ferio252 Third Gen Yaris General Discussion 18 07-13-2020 01:05 PM
yaris Advance Sedan Rudeshady Central and South America 14 06-25-2007 01:50 AM
