Old 11-06-2020, 09:19 PM   #1
Branderrp
Drives: Yaris 2006 NCP91R
Engine Coolant leaking
It's a very slow leak but would like to attend to it so I don't get any issues in the future. What should I be replacing?
The first picture shows the coolant leaking a bit in the hose on the side. Second just shows behind the cap. Third shows the side of the cap
Branderrp is offline   Reply With Quote
Old 11-07-2020, 12:28 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I wouldn't worry about that hose. Pull it off, clean it and reinstall. Maybe heat it lightly first with a heat gun to soften it so it conforms well. Replace the radiator cap. Done.
What is a (or the) coorect coolant & amount for a Yaris? RMcG DIY / Maintenance / Service 0 06-19-2019 05:36 PM
Engine Block Coolant Drain Cock Location timbstir DIY / Maintenance / Service 4 11-08-2018 02:42 AM
Oil and coolant leak jaybowblue DIY / Maintenance / Service 1 08-14-2016 10:41 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Change Engine Coolant curtqn DIY / Maintenance / Service 34 06-25-2009 11:25 AM
