Old 09-13-2021, 04:16 PM   #1
mjl1297
Drives: 2008 Yaris
Windshield wiper issue...
My wife has a 2008 Yaris and today she said she turned the windshield wipers on, they worked, and then she turned them off. When she tried to turn them on again the wipers didnít move.
So she went and did her shopping, drove home, and then turned the wipers on and off again only to have the same scenario repeat.
Any idea as to what may be going on and what I can check myself? Many thanks.
mjl1297 is offline   Reply With Quote
Old 09-13-2021, 04:56 PM   #2
bronsin
bronsin's Avatar
Figure out which fuse controls the windshield wipers and see if it’s good. If it’s not and you put a new one in end it blows, you better take it to a shop.
If the car is without windshield wipers, you can use rain off until you get it fixed. It might be a good idea to use it now in case they don’t work. Even if the rain won’t blow off at low speed, you can still see because it beats up.
Good luck and tell us what happens!
bronsin is online now   Reply With Quote
Old 09-13-2021, 04:57 PM   #3
bronsin
bronsin's Avatar
Maybe it’s a loose connector?
Old 09-14-2021, 08:18 AM   #4
mjl1297
Drives: 2008 Yaris
Thanks for the reply bronsin.
It might be a loose connection. I won't be able to check it until Friday at the earliest. When I got home late last night they did nothing when I switched them on not even a sound of the motor buzzing or anything.
Old 09-14-2021, 09:27 AM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Have you checked all of the speeds/positions on the stalk? That might help narrow it down to the switch, motor or wire harness.
Good call on the motor sounds. It's unlikely that the arms would be stripped on the shafts but that would be one possible cause.
If it was the fuse it would be an all-or-nothing issue. Intermittent operation sounds like a bad connection somewhere or the motor itself is going out.
Old 09-14-2021, 09:58 AM   #6
bronsin
bronsin's Avatar
Remember rain X is your friend!
Old 09-14-2021, 10:48 AM   #7
bronsin
bronsin's Avatar
On my smart TV I did a YouTube search for troubleshooting windshield wiper. I will post the link but I have Parkinson’s and it’s difficult using my iPad. But if you do a YouTube search you could watch The same videos. I have to believe that would solve your problem!
Old 09-15-2021, 11:51 PM   #8
mjl1297
Drives: 2008 Yaris
Thanks guys for the helpful responses. I'll have some time during my upcoming vacation to check the problem out!
Thanks for the YouTube video suggestion bronsin. I definitely believe the mechanism is seizing. They came on briefly the other night but were moving with a slow. stuttering motion and eventually stopped altogether.
Will post back with an update when I get a chance to diagnose and hopefully resolve the issue.
Old 09-16-2021, 05:06 AM   #9
bronsin
bronsin's Avatar
If you can get at the motor give it a few good wacks. Also the motor may be ok but one of the joints seized.
2010 Yaris Windshield wiper switch WalterWhite61 General Yaris / Vitz Discussion 0 06-30-2019 08:20 PM
Wiper Sync Issue GED9000 DIY / Maintenance / Service 1 01-26-2016 03:49 PM
Hose for windshield wiper broke HDS DIY / Maintenance / Service 1 04-06-2012 10:26 AM
Passenger side windshield wiper daf62757 General Yaris / Vitz Discussion 1 12-23-2011 05:12 PM
windshield wiper issue whiteghetto DIY / Maintenance / Service 7 02-15-2009 05:22 PM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
