Old 01-30-2021, 10:05 PM   #19
Neinris
Originally Posted by ElMagnifico View Post
Yes. there is a whole thread dedicated to it.
https://www.yarisworld.com/forums/sh...ad.php?t=23911...
Yup, and if you look I was the last one who posted there.
Originally Posted by ghowey View Post
I am not dropping mine, the Yaris handles pretty well from the Factory, the rear TRD bar did improve stability/cornering a good bit. I am going for a Stock Look, after all my Sedan is a Daily Driver. However, I am investigating the 2ZR-FE engine swap. Looking at the possibility of having the correct VIN in the ECU, and keep the ignition inhibitor in place!
Too bad you're not dropping your car, it's the first thing I did, and it reduced body roll fairly significantly. I dropped mine with Teins lowering springs, and it's still very daily drivable.
Old 01-31-2021, 10:45 AM   #20
ghowey
Drives: 2010 Yaris Sedan
Perfect! Thanks!
ghowey is offline   Reply With Quote
Old 04-15-2021, 11:32 AM   #21
Neinris
I forgot to reply to this. I measured the Yaris' front sway bar at 23mm, and the Scion xD at 25mm. I haven't replaced my sway bar yet, it's a PITA because you'd have to remove the subframe. It's better to do it when replacing the engine. Not sure if the xA's sway bar will fit, in case you want something just slightly stiffer, I measured one at 24mm.
3rd gen front sway bar m.flores.0928 Third Gen Yaris General Discussion 8 05-17-2017 11:09 AM
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 09:47 PM
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 02:08 AM
C-One Front Sway and 4 Point H-Brace ... SoCal DuckinOut Items for Sale by private party 3 09-13-2010 04:38 PM
C-One Front Sway Bar Jerkratt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 23 06-29-2007 10:33 PM
