Old 10-03-2020, 10:55 AM   #1
Chaosamorai
Drives: Red 07 Yaris Hatchback
Alternator bracket bolt replacement\install
Does anyone know how to go about replacing the bolt that holds the alternator bracket to the engine. Belt started squealing like mad, I found this to be the culprit. I'm not sure how to remove it to fix it. Thank you for any help you all can provide.
Chaosamorai is offline   Reply With Quote
Old 10-03-2020, 12:44 PM   #2
yangluchan
Drives: Yaris 2007
U broke bolt head
yangluchan is offline   Reply With Quote
Old 10-07-2020, 04:40 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
It's kind of a stud with a bolt head in the middle, what's left should come out with a 12 mm socket. It's holding that corner of the timing cover down so I wouldn't recommend removing it until you've got the new part.
The alternator bracket retaining nut has indeed sheared off and taken most of the threaded stud with it. It's an inexpensive part but has to be ordered from the dealership:
https://parts.villagetoyota.com/a/To...2420-1501.html
Bolt no.5 in the bottom diagram, PN 90109-08283
The nut is on a different diagram (click "more pictures" and look at the second one)
https://parts.villagetoyota.com/a/To...2420-1603.html
PN 94151-80801
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 158 05-31-2020 01:11 AM
Valve Cover Bolt Size help. please. 06YarisRS DIY / Maintenance / Service 1 01-02-2018 05:53 PM
Broken Control Arm Bolt Sirius-XM DIY / Maintenance / Service 4 02-29-2016 08:27 PM
Rounded bolt replacing belt thekatiel DIY / Maintenance / Service 13 09-29-2014 06:39 AM
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
