Old 10-16-2020, 12:03 PM   #1
RPH
Drives: Toyota Yaris XP9 1.3 VVT-i
Possible clutch actuator problem
Hi,
A couple of months ago I bought a Toyota Yaris MK2.
Some times after driving for a bit and stop for e.g. a trafficlight, I get a constant beeping sound.
It stops when I start driving again.
It's exactly the sound from this video:
https://www.youtube.com/watch?v=aP4n5Cknh20
Is it correct that I probably need to have the clutch actuator replaced?
RPH is offline   Reply With Quote
Old 10-17-2020, 10:54 AM   #2
RPH
- Checked the battery, it's a new one. No problem. About 12.8v engine OFF, around 14.2/14.4v engine ON. Wire connection seems to be OK.
- Checked the fuses in the engine compartment with a multi-meter (Ohms and Volts). All are OK.
- The battery ground is connected to the chassis, do not see something odd.
- Used an OBD2 connector to check for faultcodes, none thru two different OBD scanner apps (Torque and Car scanner).
Old 10-17-2020, 11:11 AM   #3
Someone posted a thread quite some time ago inquiring how to disable that beeping. I believe in his case, he was referring to an alarm triggered by a proximity detector, detecting something to close to the front of the car at a stop.
Old 10-17-2020, 11:15 AM   #4
Found it.
Unfortunately no confirmed resolution.
https://www.yarisworld.com/forums/sh...hlight=Disable
Old 10-18-2020, 10:25 AM   #5
RPH
Hi,
Thanks for the reply, maybe I should have added some more information.
- It's a secondhand Toyota Yaris from 2006, don't think it has a proximity sensor.
- The beeping also happens when there is no car in front of me.
Today:
- Removed all the fuses and sanded them, to make the connection better. And placed them back.
- Used contact spray in all slots.
- Removed the minus pole from the battery and sanded it, did the same to the ground connected to the chassis. And placed it back.
Old 10-18-2020, 04:29 PM   #6
Apparently European market MK2 2006 could have sensors installed.
https://www.yarisworld.com/forums/sh...ad.php?t=57270
Old 10-19-2020, 11:49 AM   #7
RPH
I see, a genuine Toyota accessory apparently.
My car doesn't have it AFAIK, no beeping when close to something.
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Getting Rid of the infamous Clutch "Shudder" tmontague DIY / Maintenance / Service 9 07-23-2016 12:25 PM
Aftermarket Clutch Q's tmontague Performance Modifications 5 03-05-2016 04:33 PM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
