Old 08-02-2018, 06:39 PM   #343
kimona
kimona's Avatar
Drives: 2014 White VITZ
Originally Posted by HDTechVideo View Post
I'm planning to change the tires. Is it ok to change from 175 65 R15 to 205 50 R15.
Im using stock alloy.
205/50/15's are a little shorter but will fit the stock alloys fine.
Tyre Diameter: 175/65/15's are 24" (609mm) and 205/50/15's are 23.1" (587mm).
You could go with 205/55's @ 23.9" (607mm).
Old 08-05-2018, 02:46 PM   #344
HDTechVideo
Drives: Yaris MK3 1.33L Dual VVT-i CVT
Thank you.
HDTechVideo is offline   Reply With Quote
Old 08-05-2018, 07:58 PM   #345
Thank you.
I already told you that weeks ago.
Old 08-06-2018, 12:47 PM   #346
HDTechVideo
Yes I do remember, but I confused with the OP.
Old 08-07-2018, 06:32 PM   #347
HDTechVideo
Ordered this one x 4
https://www.hankooktire.com/uk/passe...ime3-k125.html
205/55/R15
Sent from my SM-G935F using Tapatalk
Old 08-07-2018, 07:18 PM   #348
kimona
kimona's Avatar
^^^ That's actually an excellent choice for tread pattern; non-aggressive for a quiet ride, and a solid, continuous centre band for straight-line tracking.
Please, let us all know how they work out for you.
Old 01-30-2019, 05:43 AM   #349
rayfloyd170
Drives: YARIS
i have yaris 2016 1.3 base sedan with stock tires 175/65R14 with steel rims. I am planning to change to 15inch/16inch alloys. Would 16inch be advisable?
initially i plan on 195/55R15 but if 16inch rims will not be an issue with my smaller engine then i will go for it.
What could be the potential problems i will face later on when upgrading to tires with 16inch rims?
rayfloyd170 is offline   Reply With Quote
Old 02-03-2019, 05:34 AM   #350
rayfloyd170
Drives: YARIS
very bad, i already changed to clone OEM Rims 15x5.5 and there is no available 195/55R15 in the shop.. They only have 195/60R15. The worst part i agreed to use it...
Feels sluggish and heavy to me, considering i am on 1.3L engine only. Also i need to put more pressure while braking. If only there is 195/55R15, i guess i need to wait for another 70k KM to change tires... I hope fuel consumption would not be affected that much since now i feel i am running faster with lower RPM.. its like i am ~5km/ faster than my stock 175/65R14
Old 04-30-2019, 08:12 AM   #351
rayfloyd170
Drives: YARIS
Sold my set of 195/60R15 for half the price after using them for 2500km and used 185/60R15 instead... I cannot believe the huge difference in handling especially on corners and theres no more slouch start from my small engine, powerful start is what i need.
195/55R15 could have been much better but i dont want to hit all the crazy humps here in KSA roads.
Old 10-17-2020, 07:36 PM   #352
spoonzz
Drives: 5D YR 2012 Auto
This thread was very handy.
Looking to get 16x6.5" wheels with an offset of +40. Not sure about what tyres though!
spoonzz is offline   Reply With Quote
Old 10-17-2020, 08:59 PM   #353
kimona
kimona's Avatar
^^^ 16x6.5, ET40 is a great fitment with 205/50/16/'s on stock suspension or with a mild drop.
Old 10-17-2020, 10:42 PM   #354
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
How about a set of Accent 16" x 6.5" alloys? They're cheap, readily available, same bolt pattern, same offset as the 15" RS alloys and the Toyota center caps snap right in.
Here's my car before my coilovers:
https://www.yarisworld.com/forums/sh...ighlight=wharf
Old 10-17-2020, 11:02 PM   #355
spoonzz
Damnnn, they do look good! If anything, I want to paint it black and that seems easy enough. I'm gonna have a look on eBay and see if they pop up. Thanks!
Edit: I found some nice 16"/7" wheels with two offset options, +35 and +40. Would either be a good fitment with 205/50/16 tyres?
Old 10-18-2020, 07:02 PM   #356
kimona
kimona's Avatar
ET40 would be a better fitment with 205 rubber.
Old 10-27-2020, 12:23 PM   #357
06032
Drives: 2008 Hatchback
I see folks using Mini Cooper wheels. The 16"s I like have an offset +46-48. Is this in the realm of possibility and with what size tire for a flush look, with and without a TRD spring?
Another option I've found is a Sparco 16" wheel (from a Miata) with a 195/55/16 tire. Will it fit with or without the TRD springs?
06032 is offline   Reply With Quote
Old 10-27-2020, 04:13 PM   #358
kimona
kimona's Avatar
^^^ 16" Mini wheels are generally 16x6.5, ET48. They will work very well with 205/50/16 rubber on stock suspension or with the modest TRD drop.
Old 10-27-2020, 09:27 PM   #359
06032
Thanks, Kimona!
As to the second question, many can be found with the 195/55 rubber. Will it work for the time being?
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 98 09-23-2017 01:35 PM
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW VitzBoy General Yaris / Vitz Discussion 5 09-05-2010 08:53 PM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
