Old 05-26-2021, 04:57 PM   #1
Mrpopo2000
Drives: 2014 Toyota Yaris (manual)
2014 Toyota Yaris manual
Hello. I have a 2014 Toyota Yaris (manual) and I would like to install cruise control but I have no idea how to.
Mrpopo2000 is offline   Reply With Quote
Old 05-26-2021, 05:50 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
See This thread. It has all the information.
https://www.yarisworld.com/forums/sh...ad.php?t=37205
You will need the cruise control switch and clutch switch.
Old 10-06-2021, 04:28 PM   #3
Chriistivx
Drives: Yaris hb 2012
Did you install it? It was hard or it was not that hard? I have a 2012 manual one
Chriistivx is offline   Reply With Quote
Old 10-07-2021, 09:48 AM   #4
mannycheckers
Drives: 2009 Yaris 2dr Liftback
I installed cruise control on my 09 manual and it was very easy. You may need a drill to drill a hole for the stalk to go through the lower steering cover.
mannycheckers is offline   Reply With Quote
Old 10-07-2021, 08:50 PM   #5
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
if you have the steering wheel with radio controls, there is a pop out panel in the side of the wheel that the switch lever goes through. There is also a socket for the switch wiring to plug in.
The wiring for the clutch switch is most likely taped up, so you will need to cut some electrical tape away to get to the connectors. Without the clutch switch, the cruise control will not work on a manual transmission. The switch disconnects cruise control when you push the pedal, so the engine revs don't shoot up.
I have an automatic, so only had to fit the switch. it took longer to figure out how to get the airbag/ horn assembly off than to install the switch.
Tags
cruise control
Toyota Yaris manual Mishu47 General Yaris / Vitz Discussion 0 05-20-2016 04:13 AM
2008 Toyota Yaris 55k miles 47+MPG HWY 5-speed manual - $8300- MIDWEST/INDY alch3miss Cars for Sale by private party 0 03-18-2015 12:20 AM
GT5 Gran Turismo 5 Bluevitz-rs Off-topic / Other Cars / Everything else Discussions 144 03-04-2011 09:13 PM
