Old 05-11-2020, 01:21 AM   #1
amypang
Drives: Toyota Yaris (XP150)
Concealing scaratches
There are some scratches on my car. I don't know what made those scratches on the car. However, It just like someone rubbed sand on the car body very hard. I need to conceal those scratches until I get the car repaired. Does anybody know how to do it better?
amypang is offline   Reply With Quote
Old 05-11-2020, 04:07 PM   #2
It depends on how deep the scratches went down in the paint. A full paint correction detailing process may be needed, unless the scratches went down to the metal.
Old 05-20-2020, 11:39 AM   #3
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
If the scratches are not deep - not through the clear coat - you can lightly wet sand with 2000 or 2500 grit and then polish. The paint will look flat and dull before you polish. This is normal. In most cases, if your fingernail noticeably catches on the scratch, it's too deep to sand and polish out. You can also put touch up paint in the scratches, let it cure really well and then wet sand and polish.
Any chance of posting some pics? That would help a lot.
Old 10-02-2020, 08:57 PM   #4
justjesus
justjesus's Avatar
Drives: 2008 Liftback
I wouldn't bother with wet sanding. The Yaris paint is quite soft and compounding should be sufficient unless it's quite deep....
Yes, for the most part.
Depending on what touch up system you use, you may want to polish BEFORE applying touch up. Dr. Colorchip system is one such system that suggests polishing before touch up
But this thread is several months old!!! What became of those scratches?
Old 10-03-2020, 12:53 PM   #5
yangluchan
Drives: Yaris 2007
Did u put water on the scratches
If scratches disappear when u put water on it
Then it clear coat scratches
But if scratches did not disappear then went through clear coat
yangluchan is offline   Reply With Quote
