10-11-2020, 08:21 PM | #1 |
Drives: 2010 Join Date: Oct 2012
Fuel Spews at fill-up
Hi!
Every-every time I fill up, the pump auto-shuts off... and fuel spews from the filler - down the car and to the pavement. I'm guessing a fuel vent may be clogged, but not sure if it's a pipe, other component? Notes: . Happens at every gas station - every pump. . No Check Engine Light - ever. . It's always happened. I'm now at 135K miles. Thanks! Chuck 2010 Yaris Last edited by cdilmore; 10-13-2020 at 02:14 AM. |
10-17-2020, 12:58 PM | #2 |
Drives: Yaris T1 Join Date: Aug 2020
I think the Yaris Ninjas said it is because you overfill the tank past the first click?
https://yarisworld.com/forums/showthread.php?t=61503 check charcoal canister? I had a similar problem due to overfilling. I would have to pour petrol slowly and sometimes with a jerry can |
12-03-2020, 12:16 PM | #3 |
Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
Vent clogged or tube kinked? Check ball somewhere is not opening? Take vent tube off and force air through it and see if you can feel it coming out of fillerneck
Similar Threads | ||||
Odd Fuel pump issue. Feeling at a loss. | Marchalis | DIY / Maintenance / Service | 4 | 03-06-2018 08:55 PM |
The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
Accurate fuel fill without topping off? | sbergman27 | Fuel Economy Forum | 25 | 02-11-2012 03:58 PM |
NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
