07-09-2022, 12:37 PM | #1 |
Drives: 2012 Yaris Hatchback 3 door Join Date: Jan 2022
Should I replace coolant pump at 130K miles?
I have entire front removed, including radiator (crash). I have no idea about vehicle history - bought it wrecked. I am tempted to replace water pump, as it easily accessible at this stage of repair. The question is: Should I bother? I read these cars go 300k and even more on original pumps.
07-09-2022, 03:13 PM | #2 |
2012 does not have a history of problematic water pumps. My '06, which does have the pump some have reported issue with is still problem free after 380,000km. Leave yours in there.
07-10-2022, 01:31 PM | #3 |
Drives: 2009 Base Hatch 2 Dr Auto Join Date: Dec 2008
Leave it alone I agree
07-10-2022, 04:57 PM | #4 |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
If it ain't broke, don't fix it.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's |
07-11-2022, 09:40 AM | #5 |
Drives: 2009 yaris 2 door Join Date: Feb 2013
leave the pump
My 2009 has 295k miles with the original water pump. I had to replace the gearbox this past weekend though.
07-12-2022, 02:08 AM | #6 |
My 2007 had the original water pump replaced in 2015 as it was pink all around.
According to the authorized service center this was common issue for Yaris with this engine (2SZFE). No problem since then. I would actually say - if it is so nicely accessible now then I would go for a change (for some quality brand!). 10 years of service is quite a lot. |
07-12-2022, 11:53 AM | #7 |
Drives: 2007 5dr canadian import Join Date: Dec 2016
130k miles on a an item thats little more than 2 bearings and a seal is nothing, leave it be...if the gasket shows signs of color or weaping then by all means change it
07-21-2022, 08:16 AM | #8 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
Definitely leave it, if it has an issue down the road then change it out. It can be done with the engine in place it just is a bit more finicky.
No one ever wants to give a Yaris the point by... |
07-21-2022, 07:24 PM | #9 |
Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
I would replace it. Get a good quality Aisin.
08-12-2022, 02:02 AM | #10 |
Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
350k original everything except for a personally rebuilt alternator. These cars usually need nothing but oil
Similar Threads | ||||
Location of Water Pump | lululovesu | DIY / Maintenance / Service | 1 | 10-19-2014 08:05 AM |
Khameleon Coolant? | LilyOfTheYaris | DIY / Maintenance / Service | 18 | 04-08-2014 10:27 PM |
How many miles before you had to replace brakes, tires, battery, etc ... | Yaris_Fan | DIY / Maintenance / Service | 53 | 01-15-2013 11:52 AM |
Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
Water Pump gone at 33700 Miles | weaver615 | DIY / Maintenance / Service | 56 | 02-19-2011 02:17 PM |
