03-01-2021, 05:09 AM | #1 |
Drives: 2007 Base Sedan Join Date: Mar 2021
Torque Specs 'document' for ALL common jobs?
I've recently acquired a 2007 Yaris Base Sedan automatic, gratis. It runs and doesn't appear to leak anything, but requires a lot of work (eg: the brakes are shot & other maintenance through the years looks 'spotty').
Given there does NOT appear to be a Haynes or Chilton manual that covers this particular year/model, is there a "summary document" ANYWHERE that gives ALL the correct tightening torques for all the "common jobs"? By common jobs, I mean everything short of an engine or transmission system teardown or rebuild - though of course, there'd be no objection were those included. Or, if you like, jobs that can be done with just simple common tools in a home garage, no engine hoists or other 'fancy' stuff - just jack-stands, wrenches & the like. It would be nice to be able to just have one place to go to, one document or even just one or a couple of sheets of paper to refer to, to quickly find these torques. Some examples of common jobs I have in mind are: 1. Brake refurbishment, pads, any other worn out brake stuff, so all related torque specs required: wheel cylinder attachment bolt, bleed nipple, caliper attachment bolts etc. 2. (Automatic) transmission service, torques for pan bolts and drain plug, filter bolts & ditto for the oil pan & drain plug. 3. Torques for suspension items; strut replacement & so on ... .... Thanks in anticipation of useful replies! |
03-01-2021, 12:16 PM | #2 |
Drives: 2007 4dr sedan Join Date: Jun 2009
You should be able to find everything you want here: https://cardiagn.com/brake-2007-yaris/
03-03-2021, 03:14 PM | #3 |
Drives: White '07 3dr LB Join Date: Jun 2016
Look around you should be able to find the service manual in PDF for the 2007 yaris on here and on google. It tells you everything and how to do it. It is the Toyota issued shop manual.
03-09-2021, 03:39 PM | #4 |
Drives: Toyota Yars Join Date: Jun 2017
This is what you are looking for:
http://jdmfsm.info/Auto/Japan/Toyota...air%20Manuals/ Check the pdf titled service specifications for all torque readings. |
Tags |
specifications, torques |
Similar Threads | ||||
Motor mount bolts torque specs? AT, back "dog bone" | seatech30 | DIY / Maintenance / Service | 18 | 10-05-2023 10:17 PM |
Front Lower Arms and Ball Joint Torque Specs for 2012 Toyota Yaris LE Hatchback | ToughGuy | DIY / Maintenance / Service | 0 | 12-23-2020 08:38 PM |
Brake caliper torque specs? | imopxn | DIY / Maintenance / Service | 5 | 08-26-2019 02:13 AM |
looking for torque specs on front caliper bolts 07 yaris | mikee07 | DIY / Maintenance / Service | 2 | 10-21-2012 03:36 PM |
Suspension Torque Specs pls | nisyota | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 12-21-2010 07:04 AM |
