09-26-2006, 08:42 PM | #1 |
Drives: 2007 Yaris manual dark silver Join Date: May 2006
SPEAKER IS TALLING TOOLS AND INSTRUCTIONS
how do you make your holes/wholes for you speakers and such and what about tweeters dont they have to be more exact bucause the size of the outeer ring pictures help what kind of TOOLS
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) |
09-26-2006, 09:26 PM | #2 |
If you have to ask what kind of tools you'll need, why are YOU putting a stereo in a BRAND NEW CAR?! Call your friends.
09-26-2006, 09:31 PM | #3 |
I drive a yarrrris
Drives: 07 Sedan Polar White Join Date: Sep 2006
Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts |
09-26-2006, 09:52 PM | #4 |
Look mum no stars!!
Tools? a screwdriver?
09-27-2006, 12:01 AM | #5 |
Drives: 2007 Yaris S Join Date: May 2006
i would use a drill, hole saw, dremel, rotozip, router, use anything that will cut stuff, an exact-o-knife/utility knife, a file, sand paper, anything will work, and depending on the exact speakers, there may me a trim ring/surface mount setup that will cover up an imperfect hole ;)
09-27-2006, 05:07 AM | #6 |
Cousin Vitz
Drives: Yaris RS 5DR / Vitz RS wannabe Join Date: Mar 2006
Tweeters: Hole Saw will do the job. Mount in the A Pillar garnish or the upper part of the arm rest panel on the doors. For better sound staging, I suggest the A-Pillar garnish. Your instruction manual should state what size diameter the hole needs to be. Get the appropriate hole saw and drill it using a power drill.
Speakers: You will need custom spacers. Look up my thread on spacers (templates) for the Yaris. This will require a band saw, jig saw, and possibly a router. Mounting depth is also an issue here, so if you have enormous magnets that extend the depth past 2.75", you will need a 1/2" spacer (thickness of the bracket).
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930 |
09-27-2006, 06:32 AM | #7 |
I cut the holes (carefully) for my tweeters with a utility knife.
Thread Tools | |
Display Modes | |
