Old 12-15-2008, 05:49 PM   #19
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
THANKS!
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 06-02-2009, 03:03 PM   #20
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Bump for sticky PULLLLLEAAAASEEEEE!!!
This has been asked way too often!
Old 06-02-2009, 03:33 PM   #21
Lafiro
Drives: 06 Yaris Sedan
Hey thanks, but can you post a furthr away picture, and then a closer one please because Im having trouble finding this.
Old 06-02-2009, 03:49 PM   #22
A-tron
A-tron's Avatar
Drives: Black hb
Word I just made a thread about this. Ty for the info.
Bang those gears
A-tron is offline   Reply With Quote
Old 06-02-2009, 09:23 PM   #23
smofskra
smofskra's Avatar
Drives: 08 Flint Mica Sedan
Send a message via MSN to smofskra Send a message via Yahoo to smofskra
I'm having the same problem but it's with first and second gears mainly. I'm goin to have to try and lube that piece and see if it helps.
smofskra is offline   Reply With Quote
Old 06-02-2009, 09:41 PM   #24
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
OMG thats awesome, I really didnt wanna take the whole linkage apart to grease it all.
I cant believe Ive been living with the squeak this long because of something SO SIMPLE.
Thanks
Old 06-03-2009, 05:44 AM   #25
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
i had this problem, and dealers said it was my NST SSK...but no solution back then on here....lol
Thanks, i gotta try this.....the squeeking on mine happens when wiggling the the stick side to side during hot summer days.... hope it fixes it~
Old 06-03-2009, 04:36 PM   #26
Lafiro
Last edited by Lafiro; 06-03-2009 at 11:42 PM. Reason: Because no one answers, until they make fun of you.
Old 06-03-2009, 09:45 PM   #27
IllusionX
Drives: 07 Yaris Sedan Aero
i lubed 2 joints that were easy to remove.. turns out it is still squeaking lol. I'll have to do up the other 2 or 3 ones someday :(
automatic??? are you .... really serious ??
Old 06-04-2009, 01:38 AM   #28
texkid
The one with cheese on it
Drives: '10 Corolla S
Okay, heres my question.
With so many drivers having the same issue. Do you think this is something that Toyota should address? Like possibly a new TSB should be in order? If so, how, as a team, should we go about this?
I personally think that is bull. I am running the NST SSK and SSK-2 and not having any squeaks after applying the lithium grease. I think they were trying to avoid any "possible warranty work" by blaming on something aftermarket.
texkid is offline   Reply With Quote
Old 06-07-2009, 11:08 AM   #29
silver_os
silver_os's Avatar
Drives: Yaris Sedan
That my problem too
Thank you for how to fix it.
silver_os is offline   Reply With Quote
Old 06-14-2009, 07:48 PM   #30
ScubaSteve
Traded up!
Drives: 10 Black Sand 5-Dr RS
I can't believe I had been living with that for almost 2 years when it was such an easy fix. Thanks for the post
ScubaSteve is offline   Reply With Quote
Old 06-14-2009, 08:54 PM   #31
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Great tip, took me 2 mins. to get done. This should really be a sticky.
Old 06-25-2009, 05:53 AM   #32
silver_os
silver_os's Avatar
Drives: Yaris Sedan
very helpful
Old 06-25-2009, 07:37 AM   #33
YarisDude
Drives: Yaris Hatchback
Fixed mine too!
YarisDude is offline   Reply With Quote
Old 06-25-2009, 09:15 AM   #34
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
Originally Posted by TheSilkySmooth View Post
Now i see where the battery GND is!
it's the one with the big + next to it, right?
Originally Posted by xnamerxx
you nailed it sir.
Old 07-25-2009, 05:55 PM   #35
watersoilair
Drives: 08-2DR-MT-LB-Red
Thanks a lot for the tip...I was really starting to worry. This can be done on your own. The location of the shifting bushings is between the motor and the battery. I sprayed every rubber joint/apperatus and worked it around with the stickshift, then went around and did it once more. Make sure to use a silicone based lubricant as a petroleum based lubricant will degrade the rubber joints. Happy driving!
watersoilair is offline   Reply With Quote
Old 07-26-2009, 10:27 AM   #36
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
No GND is Minus (-) but there is no "sign" where it bolts to the transmission casing.
TheSilkySmooth is offline   Reply With Quote
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
2009 Yaris "S" - no 5MT Hatchback? Latka New YARIS Purchase Forum 21 11-07-2008 04:16 PM
New transmission at 8.5K miles! d2dailly DIY / Maintenance / Service 17 09-22-2007 11:41 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
