Old 03-09-2009, 03:17 PM   #19
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
Originally Posted by WolfWings View Post
This bit of info let me dredge up something that might explain why earlier folks had fewer issues with the throttle-body swap.
Some Corolla's came with throttle bodies with ID #22041 on the chip housing. Others have that problematic chip-housing with ID #0D031. What'cha wanna bet the #22041 chip is special in some way? :-)
ID#22041 is for vehicles with vin number starting with a LETTER (jap built)
ID# 0D031 is for vehicles with vin starting with a number (american built)
im guessing our cars do not like TB"s from american built cars.....
Old 03-09-2009, 04:38 PM   #20
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
on both cars the throttle bodies came from japan. there is no american built TB on either car. the chassis may be built here in the us but the parts may not be. i opened up my corolla tb and my yaris tb and both are made by denso japan.
Old 03-09-2009, 04:45 PM   #21
Yaris T-Sport
Nov 2006
Drives: Vitz S1600
car is running great with the new tb set up, no cels what so ever at this point
Cold Air Induction|Blitz SUS POWER Air Cleaner System|2.4L 2AZ-FE Throttle Body|Blitz Compressor System|Full Light weight pulley kit|GReddy Ti-C exhaust System|Blitz Throttle Controller|T/B Coolant Bypass + Gasket Trimmed|Weight deduction|Exhaust Manifold|Center pipe|PCV Bypassed
Yaris T-Sport is offline   Reply With Quote
Old 03-09-2009, 04:48 PM   #22
BLAZINBLUEVITZ
REALLY, toyota parts catalog lists 2 different TB's for corolla/matrix based on vin numbers. my findings were already posted.......
Old 03-09-2009, 04:51 PM   #23
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Where do you see your gains? Low end? Top end?
Old 03-09-2009, 05:06 PM   #24
mikenacarato
SIPNDEW
Drives: 15 STI
ok so you found 2 part numbers..good job. my yaris throttle body pn is different than the 08s, was my car made in the usa? i dont think so. denso japan is made in japan.
Old 03-09-2009, 05:12 PM   #25
BLAZINBLUEVITZ
im sorry MR KNOW IT ALL. i guess you can't comprehend what i wrote and i refuse to explain it to you. unsubscribed......
Old 03-09-2009, 05:38 PM   #26
FunctionSpec
Super Newbie
FunctionSpec's Avatar
Drives: 2007 Yaris Liftback White
#22030-0D030
Mine must be uber special ;)
FunctionSpec is offline   Reply With Quote
Old 03-09-2009, 05:41 PM   #27
mikenacarato
SIPNDEW
Drives: 15 STI
please feel free to explain it to me, ill listen. you said american made throttle body. the throttle body on that car is not made in america. the chassis and body panels are, but electrical and most engine components are still made in japan. go look at the sticker on a new camry or corolla and it says the percentages and what was made where. if they dont have that sticker on it, then ask them and they will go get it
Old 03-09-2009, 06:42 PM   #28
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Gains are reported to be in the mid- to high-end of the spectrum. I still have to install it to see for myself.
Old 03-09-2009, 09:10 PM   #29
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
wait wait wait.
people with the 1zz tb were getting cel's? i never got one. i did get some oscilation but only in temperatures below freezing.
could u swap the chips from the yaris 1nz to a scion tc tb? because i noticed a greater gain in power and response using the tc TB except i got thee CEL from it.
Old 03-09-2009, 09:55 PM   #30
yarstar
Drives: 2008 Absolute Red HB
Whooppee - you just got lucky. The rest of us had major CELs issues. Mine came on no matter what I did.
The gains seen with mine was major pickup mid to high end. The car really jumped @ 40 mph and continued excelerating from that point on, much stronger than stock.
Drilling out these rivets is a pain, but I'm working on it. I see you also used a allen key bolt so you keep the bolthead size to a minimum. There's one spot of the six that is super close fitting for an 'other than rivet' attachment.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 03-09-2009, 10:06 PM   #31
whooppee777
i'd rather b lucky than good.
im thinking about taking apart my tc throttle body. it sounds like something is loose inside of it. could something b broken inside of it? the 1nz throttle body sounds solid when u shake it, no noises or feelings of movement from the inside
Old 03-10-2009, 01:38 AM   #32
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Well, I'll see if I have any CELs when I receive my TB next week. Won't bother with the chip swap at first and see what happens.
Old 03-11-2009, 04:17 PM   #33
yarstar
Okay. I just performed this excellent DIY with my 2 TBs. Everything looks, feels and sounds awesome. I'll report back if I get a CEL or not. This is an excellent mod for the money.
Old 03-11-2009, 04:28 PM   #34
hatchbackkid82
Drives: .
how much do these go for and where can i get one from
Old 03-11-2009, 04:46 PM   #35
yarstar
See post #19, this thread.
Old 03-11-2009, 04:59 PM   #36
hatchbackkid82
Drives: .
Thanks just bought one from the same guy
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
