04-23-2009, 11:20 AM | #127 | |
Drives: 2009 Yaris Hatchback Join Date: Feb 2009
04-23-2009, 11:45 AM | #128 |
SIPNDEW
i just want to stress a point again. anyone who just did this mod you have to drive it for a good 2 days or so for the ecu to learn the now tb. it will oscillate bad until then.
04-23-2009, 12:01 PM | #129 |
Oh I was under the impression that the chip swap made the oscillation and CEL go away immediately. Think I should leave it on for a few days?
04-23-2009, 12:48 PM | #130 |
toyota
i guess time will tell
04-23-2009, 01:12 PM | #131 |
Yes....I would leave it on and see what happens.
04-23-2009, 02:38 PM | #132 | |
04-23-2009, 03:23 PM | #133 |
SIPNDEW
i did after the chip swap for a day or so. give it some time.
04-23-2009, 05:54 PM | #134 |
04-23-2009, 07:33 PM | #135 |
SIPNDEW
:) mine still cold idles high for a min but it goes down to normal after that
04-23-2009, 08:08 PM | #136 |
Drives: 2008 yaris, stripped, red Join Date: Jan 2009
ok.......
here's the deal....again...for you who will listen now you can stop the oscillation in less than ten minutes. after the swap, pull the plug on the battery, drain caps by hitting brakes and turning on lights plug in batt start car AND LET IDLE FOR 10 MINUTES you have to re-learn the iac sensor to the new throttle body...it is oscilating to learn the position of the iac motor....unless you have a vac leak somewhere. |
04-23-2009, 08:35 PM | #137 | |
04-24-2009, 07:56 AM | #138 |
bx in the house
Drives: toyota yaris sedan Join Date: Oct 2008
quick ? guys what's the diameter on the 1zz tb is it 2" & half or 3"
04-24-2009, 07:59 AM | #139 |
Mine's on the car, so I can't really measure it right now.
Do a search. It's on here. I think in the Performance Mod section. There's a picture of both TBs and the exact measurement of each.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
04-24-2009, 08:35 AM | #140 |
bx in the house
04-24-2009, 12:43 PM | #141 |
toyota
been 2 days anyone got rid of the issue..
04-24-2009, 12:52 PM | #142 |
I never had the issue.
I think you have an air leak somewhere in the system. Best bet is to pull the TB, and reapply the sealer and let it sit overnight to set up. |
04-24-2009, 01:13 PM | #143 |
04-26-2009, 02:24 PM | #144 |
toyota
well................anyone.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
1.8L Engine Swap, Possible? | Yaris T-Sport | Performance Modifications | 4 | 05-06-2007 06:57 PM |
swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
