![]() Drives: 2009 Yaris 5dr Join Date: Oct 2008
Rough engine start w/76?
I have a 2009 Hatchback - 6mo old. This morning had a rough engine start (cranked engine, seemed to hesistate before turning over) - this has not happened before.
Day before I filled up w/76 brand gasoline (standard octane) - I've previously only filled up w/Chevron. I also reset maintenance light (changed oil a few weeks ago). Do you think it was gas difference, or something I need to watch? |
Half a Bubble Off Plumb
Hesitating BEFORE cranking over isn't bad gas. I wonder if your battery's on its way out?
try turning it to ACC, wait couple seconds before cranking??
forgot to mention - the hesitation has not happened again - only the one time.
Is it when you crank it and it continues to try and start for a second or two like your holding
the key but you have actually let go then after 1 or 2 seconds it starts. If so, I've had this problem and so have a couple other members. Its nothing to worry about.
Brian, that's exactly what happened. Relieved that it's no issue.
Any idea on the cause of it? |
I have no idea what causes it. It happens about once every 6 months to me. No one
that I know of has had any negative effects from this though.
had the weather changed at all? if you've had the car 6 months you've likely not experienced an entire season of weather yet.
my car sometimes does not appreciate high humidity. then again my engine is on it's way out anyway.
![]() ![]() Drives: '09 Meteorite Metallic 3 dr MT Join Date: Jan 2009
I didn't see your thread when I posted mine, but I'm having the same experience now and then:
http://www.yarisworld.com/forums/showthread.php?t=19409 |
76 octane???
thats more than a tad lower than what is needed. the standard fuel around here is 87 octane. |
I think he meant the gas station 76
the slow cranking issue.. i've had it, 3 days in a row until i changed my start up habit. I don't know what could have caused it as i used it the same for a whole year when it happened.
Thanks for the input folks. Problem has not happened again - just that once.
Also found old post on same problem http://www.yarisworld.com/forums/showthread.php?t=12167. |
| yaris won't start, engine truns over but won't start. | zara616 | General Yaris / Vitz Discussion | 16 | 09-05-2021 11:39 AM |
| Engine Slow to Start | ruimond | DIY / Maintenance / Service | 26 | 04-24-2021 02:37 PM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
| Is the Yaris engine a little rough? | thomasward00 | General Yaris / Vitz Discussion | 23 | 04-30-2007 12:17 PM |
