Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > UK
Old 12-01-2010, 10:55 AM   #1
tasng4
Drives: Yaris
Yaris Headlight Swap
Hi,
I'm sure someone out there will know the answer to my problem.
A friend of mine has a '53' reg Yaris and has recently moved to France, therefore in order to import the car we need to swap the headlights for LHD ones. At first sight this seems quite straight forward, all you have to do is to remove the 2 mounting screws and slide the light towards the centre of the car................or so I thought.
Closer inspection of the light reveals a plastic pin on the rear of the light pointing to the right of the car for the right hand light (and left for the left hand light) which may prevent the sliding.
Now to my question - is it necessary to remove the front wheel arch liners to remove the headlights? This seems as though it might give better access.
It's better to have a gun and not need it than to need a gun and not have it.
You don't stop playing because you grow old, you grow old because you stop playing.
tasng4 is offline   Reply With Quote
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
New Yaris 5 DR HB arriving April 5, 2010 mkorejwo New YARIS Purchase Forum 6 04-06-2010 11:39 PM
On tire pressures, the Yaris, and the Prius sbergman27 Fuel Economy Forum 18 04-05-2010 05:35 PM
