Old 07-04-2015, 08:42 AM   #1
just1witness
Drives: 2009 Yaris Sedan
Exclamation 2009 Yaris KYB shocks NEED a boot
Maybe I am bit naive, but I found this out the noisy way yesterday. KYB shocks come without a boot, and one of my OEM boots was rusted onto the shaft of the old shock, so I researched online whether shocks NEED boots. All the sources I checked said no.
Upon test driving my bootless KYB shocks, the shafts promptly slid up into the upper opening by about 2 1/2 inches.
Thankfully it didn't cause damage, just a lot of noise, but I learned that these shocks, MUST have the OEM style boots installed, the metal top acts as a washer to keep them in place.
Just thought I would share!
just1witness is offline   Reply With Quote
Old 07-04-2015, 12:02 PM   #2
just1witness
Now I'm trying to find a replacement for the rusted OEM boot, which is proving to be impossible. Does anyone know where to get one? Should I just use a washer instead?
Old 08-14-2016, 11:42 AM   #3
oxide
Drives: Base
doing this now, how did you remove the boot from the oem shock without destroying the top washer?
Jackhouse - yer online guide to all things House news/interviews/reviews
https://twitter.com/JACKH0USE
Fridays
sHIFT Radio 101.5 9-11pm http://www.umfm.com
http://soundcloud.com/oxide
http://oxide.bandcamp.com/
07 Yaris HB
05 Yamaha Vino 70CC Heavily Modded
oxide is offline   Reply With Quote
Old 08-14-2016, 12:35 PM   #4
Tapokata
Drives: 2009 Yaris
Is this for the rear shock? The Rear shock strut fits through a support tube (boot) (48750-52100, about $28 at the dealer) then through a rubber stopper (48752-52010,~ $8) below the the mounting plate. The strut is then captured by the top bushing, bushing retainer and lock nuts.
Tapokata is offline   Reply With Quote
Old 08-14-2016, 12:40 PM   #5
oxide
Drives: Base
yup
the oem boot is all one piece at the top, tried twisting it off but that doesn't work
Fridays
07 Yaris HB
Old 08-15-2016, 10:06 PM   #6
Tapokata
Drives: 2009 Yaris
Those part numbers are valid for OEM parts. You should probably source the top bushing (48755-52010), bushing retainer (90201-10320), and lock nuts (94130-61000) from the dealer as well, given the amount of rust. Coat the cushion and the bushing with a liberal amount of syl-glide silicone lubricant before you reinstall it. The silicone will help the cushion and bushing stay where you put it
Make sure you've to the wheels on the ground before you torque down the top nuts- set the lower nut so you have about 15mm of three revealed on the strut, and then torque the top nut to 18 ft-lbs of torque.
Old 08-16-2016, 09:27 AM   #7
oxide
Drives: Base
waiting on delivery from the dealership now...
thanks for the help
Fridays
07 Yaris HB
Old 08-16-2016, 08:23 PM   #8
Tapokata
Drives: 2009 Yaris
Been there, done that, got the t-shirt. The thread illustrating my screw ups is stickified in this section.
Old 08-23-2016, 06:02 PM   #9
oxide
Drives: Base
well that worked out good cept for the bolt i snapped but all is well now. damn these new shocks are much better
Fridays
07 Yaris HB
boot, boots, oem, shocks, shocks replacement
FS: 2009 Yaris 3dr left-overs jecurtin3 Items for Sale by private party 12 08-09-2013 02:57 AM
Just bought: 2009 Yaris Sedan Prometheus Bound New YARIS Purchase Forum 2 05-11-2013 11:45 PM
