Old 10-03-2014, 01:58 PM   #1
Redflow2014
Redflow2014's Avatar
Drives: Yaris d4d
Hello, EGR question:)
Hi all
New member here.
I have a 2002 Yaris D4D. I would really like to delete or block the egr valve, not because it's stopped working or causing me any problems but just because I don't believe it is needed and that hopefully I might get better fuel consumption.
Now I've searched the Internet far and wide and I can't find any how to's.
I've played about a bit with it and the vacuum hose that comes off the egr and goes into a green plastic thing ( sorry will post pics tomorrow) I pulled that off and it had no effect at idle until I stuck my finger over the suction hole and car nearly cut out, then when I asked my brother to rev the car to around 3.5k I again stuck my finger over the suction hole and it had no effect.
Now I'm assuming that the egr valve only is working at idle, and therefore if I leave the pipe disconnected that will basically bypass/delete the egr? Or is there a kit I can buy to delete?
Thanks hope I haven't lost anyone
Sent from my iPhone 5 using Tapatalk.
Redflow2014 is offline   Reply With Quote
Old 10-03-2014, 02:11 PM   #2
The best way to bypass the EGR is with a blanking plate between it and the exhaust manifold. That way the ECM stays happy (no check engine light). If you search on ebay in Europe you may be able to find a pre-fabricated one for your 1ND-TV.
Old 10-03-2014, 05:25 PM   #3
Redflow2014
Drives: Yaris d4d
Ok thanks. But what about what I said?
Old 10-03-2014, 07:22 PM   #4
It works in idle as well as at rev. The effect of leaving it open is just more noticeable at low RPM, as you are basically doing the same as creating a vacuum leak when you just pull the hose.
Old 10-03-2014, 07:32 PM   #5
Redflow2014
Drives: Yaris d4d
I can't find a blanking plate anywhere!!
Old 10-03-2014, 08:32 PM   #6
Hilux ones are readily available, but I don't see any Yaris ones out there. If you look at the Yaris EGR, it looks like the plate would be fairly simple to fabricate out of a piece of sheet metal.
Old 10-04-2014, 02:54 AM   #7
Redflow2014
Drives: Yaris d4d
Old 10-04-2014, 07:12 AM   #8
Redflow2014
Drives: Yaris d4d
Hey guys I just took some pictures.
This is my egr valve
So what I'm asking is. The little black suction hose that goes into the EGR valve if I take it off, the car will work fine and the EGR will be bypassed?
The fifth photo also shows a component that moves when the aforementioned pipe is disconnected further reinforcing the idea that said pipe "turns off " the EGR valve?
Also their are two holes going from EGR to manifold not seen an EGR shaped like this before??
Thanks.
Old 10-04-2014, 07:14 AM   #9
Redflow2014
Drives: Yaris d4d
Old 10-04-2014, 08:11 AM   #10
Redflow2014
Drives: Yaris d4d
Anyone ?
Old 10-28-2014, 09:19 AM   #11
Redflow2014
Drives: Yaris d4d
Bump
Sent from my iPhone 6 + using Tapatalk.
Old 10-28-2014, 09:29 AM   #12
If the EGR valve stays closed when you remove and plug the vacuum hose, then I would agree that is sufficient to bypass it.
Old 10-28-2014, 11:18 AM   #13
jcboy
Drives: Sedan 07
usually it's just a blockoff plate as toyota fortuners and mitsubishi monteros (popular midsize SUVs here) do that.
you can google and ive posted one of the results for such:
http://www.thaivisa.com/forum/topic/...ing-egr-valve/
Old 10-28-2014, 01:25 PM   #14
Redflow2014
Drives: Yaris d4d
Ok so I'm going to fabricate a blanking plate myself because I cannot find a premade one.
Please tell me do I block the part with two holes (pic 3 post 9?)
Thanks.
Old 10-28-2014, 02:42 PM   #15
jcboy
Drives: Sedan 07
As ctscott mentioned, it can be as simple as a thin aluminum sheet cut on the outside border the same as the seemingly y-shaped design left on it on the pic. Include the holes for 2 bolts so it stays in place.
Im not sure if you need to remove/block the small tube for air but if i guess right it's purpose is to simulate a cold engine so that the egr valve is closed? Not sure though.
Old 05-07-2018, 01:09 PM   #16
drusoider
Drives: Toyota mk1 1.4d-4d
How went the car after blanking the Egr?
Thanks.
Sent from my MI MAX 2 using Tapatalk
drusoider is offline   Reply With Quote
A little 2009 styling question... stevethegimp Cosmetic Modifications (Exterior/Interior) 0 02-12-2011 09:19 AM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 05:44 PM
