Old 08-05-2007, 01:56 PM   #37
NonStopTuning
THANK YOU for all the kind words everyone, I appreciate it.
We work very hard to bring you excellent products at great prices, and your kind words make all of the long days well worth it!
Enjoy your NST goodies and stay tuned!!!
MIKE @ NST
www.NonStopTuning.com
Old 08-22-2007, 05:34 PM   #38
NonStopTuning
Any new user reviews? comments/questions?
MIKE @ NST
Old 08-22-2007, 08:15 PM   #39
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Would NST consider making a Version 2 of the short shifter that gives a little longer throw and lighter shift action?
Perhaps 50% of the stock throw?
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 08-22-2007, 11:04 PM   #40
cdmyaris
cdmyaris's Avatar
Drives: 07 Yaris Liftback
i bought it awhile ago. It was my first mod. Easy install took me like 5 minutes. It was hard at first but for couple of miles, it was smooth and short. NST does make a great products! Now, cant wait for pulley, alt, and water pump kit!!
Toyota Yaris FTFW!!
cdmyaris is offline   Reply With Quote
Old 08-24-2007, 07:18 PM   #41
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I've just driven my car after almost two months of waiting. I installed the SSK while it was still being worked on and the stock intake was removed, so it was extremely simple to setup.
As far as the feel goes, it's certainly an improvement over stock, although it does make a bit more strength to get it into the proper gear. I'm thinking one out of two will happen: Either it will become softer after a while, or I'll get used to it.
Either way, I'm loving this mod so far. It does make the Yaris more fun to drive. Oh, and the price is pretty good too.
Keep up the great work, Mike! Looking forward to installing the rest of the NST goodies!
Old 08-31-2007, 07:10 PM   #42
SDsurfrider
SDsurfrider's Avatar
Drives: 07 Sedan S
Just installed mine today. Thanks to Paul and the guys at Dezod as well as Mike and the NST team and of course all of you who contribute to YW.
I would call it a firmer feel with more precision. I have no problems shifting into 5th or reverse like other members have reported.
I agree with KIOSHI that this SSK gives it a feel much like that of the 350z/G35.
SDsurfrider is offline   Reply With Quote
Old 09-01-2007, 02:56 PM   #43
NonStopTuning
Thank you very much for the kind words, we appreciate it
We work very hard to bring you guys quality products at an excellent value, and our name has stood the test of time very well over the past few years.
I'm guessing you ordered this piece from Dezod... a great place to inquire about anything motorsports related. Dezod FTW
MIKE @ NST
Old 09-04-2007, 05:21 PM   #44
SDsurfrider
Drives: 07 Sedan S
I did indeed order mine through Dezod; quality professional service handling a quality professional part!
<-- another satisfied customer to add to a very long list.
NST FTW
Old 09-27-2007, 09:34 PM   #45
NonStopTuning
Very nice. Keep the reviews coming guys and gals
Old 10-19-2008, 11:46 AM   #46
NonStopTuning
Anyone else?
Old 10-28-2008, 10:43 PM   #47
execute
Drives: Toyota Vios 08
Just installed my short shifter that I bought from cali yaris' store. Shifts really stiff and short, as advertised.
I have one problem though, I couldn't get the OEM pin that's supposed to go into its original hole to secure the short shifter to the original pole. I went ahead and put the rest on with no problem, you guys think that's ok? This is probably due to some design differences with the USDM ones from our local ones (Philippines). And I have a 2NZ-FE engine which is a 1.3 variant of the US ones. I haven't driven it but I did try to shift and it seems to work as advertised. Is that ok?
execute is offline   Reply With Quote
Old 10-29-2008, 12:09 AM   #48
NonStopTuning
Hi John,
You should be ok. We suggest checking your SSK from time to time to make sure that everything is in the correct place, and working properly.
Good luck and have fun with your project!
MIKE @ NST
Old 10-29-2008, 01:45 PM   #49
stratkid2004
Drives: '08 black hatchback 3dr
so I saw on a later thread that the kit in the engine bay has a 30% shorter throw, the one in the cab has a 25%shorter throw. Is this true? The one that goes in the cab I saw was a little cheaper, so does the extra 5% make that big of a difference? Is it worth the couple extra dollars?
stratkid2004 is offline   Reply With Quote
Old 10-29-2008, 01:46 PM   #50
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
You just said it's a couple extra dollars. Stop being a cheapskate and buy the engine bay one! ;)
Old 10-29-2008, 02:38 PM   #51
stratkid2004
haha your right
Old 10-29-2008, 09:11 PM   #52
NonStopTuning
This is a good question.
The traditional engine bay SSK, NSTSSK09, has been available for a long time, and is the easier of the two to install and remove. Most people use this version.
The newer in-cabin SSK, NSTSSK09-2, is also a great item and is cheaper, but requires a little bit more effort for installation.
These different pieces have been designed to give you options and choices, and to allow the more ambitious owners to have a combo that will provide a very very short throw, when both pieces are used.
You can use either/or. Decide what works best for you, and buy the one you like, or buy both!
That is the NST way
MIKE @ NST
Old 10-30-2008, 06:40 AM   #53
Midon
Mod Freak
Drives: 88 MR2 GT
I have a question. Does this kit get rid of the mushy felling when you shift?
Midon is offline   Reply With Quote
Old 10-30-2008, 07:22 AM   #54
tk-421
tk-421's Avatar
Drives: 5D-07-LB
It helps a lot, especially when coupled with the shifter cable bushings, and some Redline MT-90.
NST (NonStopTuning) Pulleys. Info, Specs, User Data... NonStopTuning Performance Modifications 636 12-13-2013 09:47 PM
NEW GROUP BUY: NST Short Shift Kit (NonStopTuning) NonStopTuning NonStopTuning 245 08-28-2007 03:53 PM
short shift: NST or TRD? cali yaris Performance Modifications 21 07-07-2007 03:38 PM
