Old 11-29-2023, 03:54 PM   #1
mik36
Drives: VERSO S
YARIS 1.3 Vaccum from EVAP line
Gents
I had this strange issue in 1.3 petrol engine the evap line I can feel have a high pressure vacuum
When I open the tank cap I feel hissing noise feel pressure released
Is this normal
I was looking at the evap purge valve which has one line from fuel tank evap this line has got vaccum in it and when I removed the finder the rpm increases this line connected to black pipe in the valve there is grey one from this valve which i believe goes into engine
No codes.
When I remove my finger from evap line the rpm increases and LTFT jumped to 9
Any help to test cross check would be highly appreciated
mik36 is offline   Reply With Quote
Old 11-30-2023, 09:39 AM   #2
komichal
Whenever I remove the tank cap I actually do not hear hissing. I hear clapping as there is negative pressure in the tank that sucks air from outside and I guess there is some protective shutter that that makes the clapping.
Driving Yaris 2007 hatchback with 2SZFE 1.3 engine. Bought it in 2012, always behaves like that, never threw a code, never had any problem with this.
Old 12-01-2023, 01:09 AM   #3
Compeer
Drives: NCP90 TRD Yaris Manual
Originally Posted by mik36 View Post
Gents
Is this normal
No codes.
Normal, all my toyotas hissed like theirs vacume in fuel tank when i get gas, current yaris does it too. never ran it without cap on to notice any change,
Compeer is offline   Reply With Quote
Old 12-07-2023, 02:31 AM   #4
zoidberg444
zoidberg444's Avatar
Whenever I take the fuel cap off mine it always hisses as air rushes into the tank. I always assumed the EVAP system kept the tank under vacuum in order to draw petrol vapours from the tank into the intake to prevent them off gassing to atmosphere.
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles
UK to Nordkapp in a Yaris
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 11:56 AM
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
Which second hand Yaris to buy? 1.5-1.8 T Sport or 1.3 base? REs Third Gen Yaris General Discussion 5 07-06-2011 04:08 AM
