Old 05-15-2009, 04:29 AM   #1
gwasabi
Drives: 07 Blazing Blue LB
Seatbelt Temp Chime turn off option
So since I have a harness, I was trying to figure out how the hell I'm going to turn that friggin chime and seatbelt warning off. This was my solution.
The Seatbelt On and Off Switch.
I used the existing AUX jack because I have no use for it abnymore since my stock one is broken and I have a new aftermarket HU anyway.
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-15-2009, 04:51 AM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Old 05-15-2009, 04:56 AM   #3
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
DIY! Lots of people could benefit from this mod!
Old 05-15-2009, 05:00 AM   #4
tk-421
tk-421's Avatar
Drives: 5D-07-LB
DIY is located here: http://www.yarisworld.com/forums/showthread.php?t=3587
Old 05-15-2009, 05:30 AM   #5
Sabretooth
37HSSV
Sabretooth's Avatar
HurraH!
Old 05-15-2009, 06:05 AM   #6
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
Where did you get the switch that fills up the blank slot exactly.
PG TLD22 8V Line Driver
Old 05-15-2009, 09:04 AM   #7
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
goodness, this thread pops up a lot. howabout go to the dealer, 15 mins later free of charge, its gone
mikenacarato is offline   Reply With Quote
Old 05-15-2009, 09:17 AM   #8
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
pull the plug out of the seatbelt latch
problem solved
Originally Posted by xnamerxx
you nailed it sir.
Old 05-15-2009, 09:28 AM   #9
No dealer around here would disable an important safety feature like this. mikenacarato, are you sure?
Old 05-15-2009, 09:38 AM   #10
mikenacarato
SIPNDEW
Drives: 15 STI
positive, even says so in the owners manual. plus, ive had it done at my dealer already.
Old 05-15-2009, 10:45 AM   #11
1stToyota
1stToyota's Avatar
Seatbelt extension is the easiest solution. Dealership gives them out for free (written in your owner's manual), nothing to reprogram, just plug in and tuck extension between seat and console.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 05-15-2009, 02:20 PM   #12
gwasabi
the dealer wont do it on the driver's seat.....
Serious Business...
Old 05-15-2009, 02:25 PM   #13
you should put a sticker that says "Ejection Seat" above it
Old 05-15-2009, 02:30 PM   #14
Tamago
Tamago's Avatar
Drives: ZZW30
are we all ignoring the easy solution of unplugging the actual switch that goes to the seatbelt latch?
you nailed it sir.
Old 05-15-2009, 02:51 PM   #15
mikenacarato
SIPNDEW
Drives: 15 STI
yes they will.
Old 05-15-2009, 03:13 PM   #16
if you unplug the switch at the seatbelt latch, don't you get a flashing seatbelt sign or something like that?
Old 05-15-2009, 03:43 PM   #17
Tamago
Tamago's Avatar
Drives: ZZW30
you're correct
so. if your dealer won't disable the drivers side warning for you (which is possible, per the toyota service manual)
you can do this:
put a 20Kohm resistor between pin 3 and 4 under the seat
you nailed it sir.
Old 05-15-2009, 05:00 PM   #18
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Interesting... Will that mess with the airbag deployment at all? The guy that sold me my car told me the airbags will not deploy if the passenger isn't wearing a belt. He said you are worse off if the airbag were to deploy that way. Probably
seat belt chime disable? Lewis DIY / Maintenance / Service 19 05-25-2012 04:36 PM
Anyone find out how to turn off the seatbelt chime? overboost General Yaris / Vitz Discussion 54 11-22-2008 10:07 AM
what water temp does cooling fan turn on gonzo452001 General Yaris / Vitz Discussion 10 11-07-2006 05:50 AM
