Old 02-17-2010, 05:35 AM   #37
kazama82
Drives: VIOS
i think if we want to used normal LED, we need 1K ohm resistor install together..
kazama82 is offline   Reply With Quote
Old 02-17-2010, 05:57 AM   #38
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
I didn't use any resistors. It's straight up plug 'n play. I can't remember where I got the LEDs, but I'm almost 95% certain they're the standard white LEDs from Advance AutoParts.
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs
enobmort42 is offline   Reply With Quote
Old 02-17-2010, 06:34 AM   #39
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by Revsson View Post
If it's not on while you are driving, then I would think it is okay to do.
Nice idea!
Actually, what if the LEDs were wired to the side blinkers? I think it would be sorta functional and look pretty cool (probably have to be in amber to be legal though).
Old 02-17-2010, 08:42 AM   #40
kazama82
Drives: VIOS
actually, here we have this kind of handle..dunno if we have it in the states..
Old 02-17-2010, 08:45 AM   #41
kazama82
Drives: VIOS
i will try to asked the shop tomorrow if the LED can sustain 12V..i tot of putting like small o-ring surround the LED as here, we have plenty of rain..afraid i will short something..
Old 02-17-2010, 12:28 PM   #42
enobmort42
First time DIYer
enobmort42's Avatar
That could work. What I've found is you can hot glue it in there, too. It seals it up nice and keeps it from going anywhere. I'm interested to hear back about the resistors, though. While I don't think they're necessary, it doesn't hurt to be 100% :-p
Old 02-17-2010, 07:24 PM   #43
kazama82
Drives: VIOS
hi enobmort42, can you snap a picture showing how u hookup the wiring at the blue and pink wire?..do you just tap the wire?
Old 02-17-2010, 10:41 PM   #44
enobmort42
First time DIYer
enobmort42's Avatar
Sure, I'll do that in the morning when it's lighter out. It's pretty simple to find..
Old 02-17-2010, 11:26 PM   #45
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
ooh. I want a set of those.
Old 02-17-2010, 11:53 PM   #46
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
How about we get together n do the OPs mod
Old 02-18-2010, 01:56 AM   #47
RHDVIPbB
hey, I am down. Let me know
Old 02-18-2010, 04:40 AM   #48
kazama82
Drives: VIOS
my place, quite cheap..less than USD100..the blue light will connect to small light, the amber will connect to the blinker..very neat..you can always connect the blue light at the dome light if you want..
Old 02-18-2010, 06:44 AM   #49
bitz767
Drives: 2010 Black Manual 3 door
Could there be a way to make the handle light up after you press the unlock button on the power lock remote?
bitz767 is offline   Reply With Quote
Old 02-18-2010, 01:35 PM   #50
enobmort42
First time DIYer
enobmort42's Avatar
Does your dome light come on when you unlock your car?
Old 02-18-2010, 02:49 PM   #51
bitz767
lol, i checked that this morning when I got in the car, and it does.
I think it would be sweet at night to have the handles light up when you go to the car. Being a 3 door, this mod looks very doable...
So you Louisville guys want to get together and do this sometime?
Old 02-18-2010, 05:29 PM   #52
DandiDani
DandiDani's Avatar
i do
Old 02-18-2010, 08:05 PM   #53
kazama82
Drives: VIOS
i plan to do soon also..:)
Old 02-18-2010, 09:15 PM   #54
enobmort42
First time DIYer
enobmort42's Avatar
The connector (4K) on the upper left in this picture, is the feed to the map and dome lights. White with a black stripe ground, Pink is the "door open" switched ground, and blue is 12V fed from the DOME fuse.
To quote a thread I found on another thread. I would have taken this same picture...
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
