11-15-2009, 09:20 PM | #37 | |
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
Hahahaha!! |
11-29-2009, 05:54 PM | #38 |
Drives: '09 Yaris Sedan Join Date: Oct 2009
What sway bar did you add Lweis? I leased this car so anything I would add needs to come off easily.
doc |
12-02-2009, 08:18 PM | #39 |
Drives: car Join Date: Oct 2008
All sway bars install the same and in under 10 minutes by a knowledgeable person. The thicker the bar the more roll resistance that is added. But obviously for you hypermilers, thicker = weights more = slightly less MPG. So take it for what it's worth.
There are 19mm, 22mm, and 23mm swaybars for the Yaris. |
12-02-2009, 08:53 PM | #40 |
Drives: 07 Yaris Turbo Join Date: May 2007
There are only 19mm and 23mm as far as I know. TRD is 19mm.
UR 19mm = 12 pounds UR 23mm = 15 pounds
12-03-2009, 07:07 PM | #41 |
Only Happy When it Rains
Ouch!!! So much for getting one of those.
Colin Chapman disciple |
12-03-2009, 08:58 PM | #42 |
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
Conventional wisdom says that a Yaris loses about 1mpg for every 100 pounds that is added to it. So, a 12 pound swaybar would maybe take away .12 mpg.
Honestly, I do think that slowing down less for turns (that you'll be able to do more confidently after adding the swaybar) would make AT LEAST that much of a difference. |
12-04-2009, 10:42 AM | #43 |
You are right for normal peoples, and if i were to even think about any type of racing it would prolly be a must add. But I am kinda nuts, and am planning on removing the rear interior pieces for weight reduction soon. Just a bit lazy, lol.
As for corner confidence, I love that rear end stepping out, that stuff is just fun. Drifting is my type of entertainment. Speed up into the corners, don't slow down! lol losing control because you're too fast into a corner and you hit the grass is kinda nuts. I need to learn more about drifting.
Similar Threads | ||||
DIY - rear sway bar [pics] | cali yaris | DIY / Maintenance / Service | 199 | 07-28-2022 05:25 AM |
Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
Rear Sway Bar Instructions - Additional Pics | SeaYa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-26-2009 01:05 PM |
solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
Best place to purchase a Tanabe strut bar and or TRD Rear anti sway bar? | thomasward00 | General Yaris / Vitz Discussion | 3 | 07-12-2007 01:22 AM |
