Old 09-21-2009, 01:00 PM   #1
ECU Wiring Diagram?
anyone have the ecu diagram for an 07 yaris hatch? searched, but can't find it...
Old 09-21-2009, 01:12 PM   #2
BLH
Drives: 2007 Yaris Sedan
Closest I have seen is in section 5 of the EWD.PDF file part of the service manual. I downloaded from a thread here.
BLH is offline   Reply With Quote
Old 09-21-2009, 01:46 PM   #3
http://www.etimago.com/yaris/repairmanual/
thanks to etimago for this one...
Old 09-21-2009, 10:35 PM   #4
Here's a chart that I put together. The connector pinouts are at the end of the EWD. I went through the EWDs to figure out every used pin on the two connectors.
In case you are wondering about the highlighting - They are the pins needed to fire up and ECM on the bench. The ones highlighted in red are the ones that need +12V and the yellows are the ones that need to be grounded.
Yaris ECM.pdf
Old 09-21-2009, 10:42 PM   #5
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
wow, very nice!!
Old 09-22-2009, 03:49 AM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Well done CTScott!
Much
Old 10-06-2010, 06:12 PM   #7
miketrd
Drives: yaris ts
Hellow all
I bought an 1nz-fet - NCP13 Vitz TRD engine with turbo from yahoo jpctrade auction.
By trying to put the motor on my car we found the following problem: The 2 sockets with wire from ecu to car speedometer are missing. I attach a photograph (111.jpg) to show the missing sockets.
So we found 2 sockets which match but we haven't the terminals of ecm (ecu pinout - wiring diagram) to construct the cables.
In addition to the above my car is Toyota Yaris TS 1.5- NCP13 2002 and the vitz trd engine is from a vitz rs turbo 2003 model (facelift). So the 2 harnesses are different.
I want to ask you someone have the pinout diagram for this or where could i find it?
Thanks in advance
miketrd is offline   Reply With Quote
Old 10-06-2010, 06:38 PM   #8
sleey0
Drives: 2008 Yaris LB
Goo luck finding that. Ouch.....
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 10-06-2010, 09:17 PM   #9
Originally Posted by miketrd View Post
Hellow all
Thanks in advance
I think I have everything that you need. PM me your email address and I'll email you the pdf's.
Old 10-06-2010, 09:54 PM   #10
sleey0
CT just has every wring scheme imaginable!!!
You keep on surprising me:)
xbgod - 9/23/2010
Old 04-05-2015, 12:53 PM   #11
happyshadrack@gmail.com
Drives: echo
1nzfe engine pin-outs
CT please send me the same PDF. I have the same problem here with a new engine
happyshadrack@gmail.com is offline   Reply With Quote
Old 04-05-2015, 12:57 PM   #12
Drives: echo
Smile yaris ecu wiring pin-out
Hellow all
Thanks in advance
please forward me the pdf from CT if you can, bought a new enine with the same problem
Old 09-27-2015, 11:04 PM   #13
Kaws Wong
Drives: NCP10 Vitz 00
HI MAte,
I have the same problem also, would you please forward pdf diagram also?
Thank for your help.
BR.
Kaws
Kaws Wong is offline   Reply With Quote
Old 05-19-2018, 06:12 PM   #14
Juan Perez
Drives: Yaris ts
does anyone have the diagram?
Could tell me where i can find it
Just build a yaris TS with turbo and need the pinout diagram for the ECU vitz turbo (1nz-fet - NCP13 Vitz TRD)
thanks
Juan Perez is offline   Reply With Quote
Old 09-27-2019, 09:42 PM   #15
Sd2jza70
Drives: 2005 Scion xb
I’m in need of the diagram for the 1NZ-FET trd Turbo ecu if anybody would be so kind as to share it :)
Sd2jza70 is offline   Reply With Quote
Old 08-12-2022, 05:07 PM   #16
Huevito
Huevito's Avatar
In need of the diagram for the 1nz turbo also can someone help if anyone is still out there?
Huevito is offline   Reply With Quote
ecu wiring, ecu wiring diagram, wiring
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 06:15 PM
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 6 04-25-2009 08:11 PM
Wiring color code for 2008 LB? charles nelson DIY / Maintenance / Service 0 04-25-2009 03:56 PM
NEED TPMS Wiring Diagram please mikenacarato DIY / Maintenance / Service 9 02-11-2009 11:55 PM
