Old 11-21-2006, 10:55 PM   #1
Bones
Bones's Avatar
Drives: 07 Yaris S Type
DIY Trunk soleniod
Using a standard trunk solenoid, I added a bicycle brake cable housing to the solenoid’s cable. I notched the side of the latch cover. Then I hooked or tied the solenoid’s cable to the same latch as the stock one.
There are only two wires. One goes to ground, the other to a relay for a momentary switch or the AUX button on the alarm. I routed the wires along the factory wires.
Bones is offline   Reply With Quote
Old 11-21-2006, 11:07 PM   #2
Cool, so how do you operate it?
Old 11-21-2006, 11:09 PM   #3
ChinoCharles
Drives: LB
Either with a button in the car or if you're really slick you hook it up to an aux on your aftermarket alarm system so you can operate your trunk release from your key fob, thus opening up the option of shaving your stock trunk release.
This thread title is misleading though, because this is not a DIY! This is a teaser!
Old 11-21-2006, 11:42 PM   #4
Understood, thanks for the update!
Shaved hatch handle sounds pretty cool, the trunk release does look quite low-tech on the HB
So yes, more details on the installation process please!
Oh and, it's interesting to see the emergency hatch opening handle on the inside, there goes my dream of carrying kidnapped people in my trunk
Old 11-22-2006, 01:42 AM   #5
spkrman
Drives: 1
kidnap a small child or a midget, sure :)
Old 11-22-2006, 08:16 AM   #6
the_saint
50% borikén
the_saint's Avatar
Drives: 06 Mazda5, 90 240sx
Yeah, here in america they always ruin the fun.
'06+ Toyota bB
Garson - D.A.D. aero
Zuenglein Dolci wheels
the_saint is offline   Reply With Quote
Old 11-22-2006, 09:21 AM   #7
well dead bodies would be all right I suppose.......
Old 11-22-2006, 10:29 AM   #8
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
bones, anyway you could give a step by step write-up on this? Also what size/type/brand is the sol? and where'd ya get it from?
I've been wanting a power trunk....
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Old 11-22-2006, 04:30 PM   #9
spkrman
Drives: 1
IMO yaris would look awesome with that funky lock shaved off the rear.
Old 11-22-2006, 07:39 PM   #10
Bones
Bones's Avatar
I used a Viper 522T, about $40.00 at Circuit City. It’s a fairly generic solenoid and sold by different brands.
Looking at the third picture:
1)I bolted the mounting bracket first. Try to line up the solenoid, same angle that it would pull the latch. Straight shot.
2) Install the solenoid in the middle of the adjustment screws. This way, you can adjust the pull upwards or downwards. More tension or less.
3) The way the solenoid works is when you apply power to it, the cable is pulled real hard for a second. Ground and power does not matter which post you connect it to. In the picture, it is grounded right to the trunk. Just a few inches away, can’t see it because of the Dynamat.
4) Power wire. This wire runs up to the dash, to the alarm. I un-tapped the factory wire loom running on the driver side and ran the wire inside the looming. Then I re-taped it.
5) Notch the plastic that cover the trunk latch just above the stock trunk release cable.
6) I used a standard bicycle brake cable housing to slide over the steel cable of the Viper solenoid. The length of the housing should line up with the stock trunk release cable. The uncut or covered end of the housing should be towards the latch.
7) See picture
8) See picture
9)See picture
10) I made a loop with the Viper solenoid steel cable by soldering. The solenoid comes with a steel cable attachment, but it was a little bulky so I opted to solder it. The tension should be tight but not to tight. You can do small adjustment by moving the solenoid up or down (step 3).
11) You can test by touching the power wire to 12volts for a second. The trunk key and stock release cable are still operational.
12) To hook up to the alarm refer to my original post
"Official" Yarisworld.com DIY Manual vodkalush DIY / Maintenance / Service 41 11-02-2023 11:47 PM
DIY Spacer Templates for Speakers - Hatchback bigsky2 DIY / Maintenance / Service 9 09-22-2007 06:16 PM
"Offical" YarisWorld.com DIY Manual vodkalush DIY / Maintenance / Service 17 12-19-2006 09:32 PM
Trunk issue Lowfront In Car Entertainment + Electronics (audio / video / alarm) 1 09-24-2006 06:55 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
