Old 10-13-2006, 07:43 AM   #73
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Nope... Consult Tanabe for any questions you may have. Or ask Chris who has talked to them directly. They are cake to install and will save you some good money.
slvryaris is offline
Old 10-13-2006, 08:58 AM   #74
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
Drives: 07 Red Yaris S & 95 Miata
Will do. Thanks!
Don Neudecker
Ad Compositor Extrodinaire
"The instructions are inside the box." - My I.T. Dept.
Lizardboy is offline
Old 10-13-2006, 06:49 PM   #75
slvryaris
slvryaris's Avatar
I have the NF springs on mine and the stock shocks perform ok still. I am sure that it does cause some premature wear but not enough right off hand. My NF's feel like I am floating on a cloud. I would dare to say that my NF's feel better then the stock suspension.
Old 10-14-2006, 12:39 AM   #76
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
Better than stock? That's sweet! I guess I'll take a chance with the DF's. I'm hoping that if they're too stiff for me I'll be able to sell them on Yarisworld or on Ebay if need be and downgrade to the NF's. I think it's time for me to MAN-UP! I've got the tint that I can't see through at night and the horns that make grown men jump when I put them on blast! Might as well keep going!
Don Neudecker
Old 10-14-2006, 06:00 PM   #77
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
it wont be too stiff, ecpically with the stock struts/springs. It works perfect with the stock components.
I on the other hand, would still like to get firmer shocks/struts and finish the rest of my suspension mods (sway & rear strut bar).
Chris07LB is offline
Old 10-14-2006, 06:51 PM   #78
YamilR
YamilR's Avatar
I installed my DF210 today. HOLY CRAP WHAT A DIFFERENCE!!! I swear they feel better than stock. I use this DIY a couple of times as a reference and couldn't be any better. I also installed a Tanabe Medallion exhaust and AEM CAI I will take pics tomorrow if I get my rims installed, so Thank You Chris07LB
YamilR is offline
Old 10-14-2006, 06:52 PM   #79
Chris07LB
Chris07LB's Avatar
Welcome buddy!
I bet she sounds mean with your intake / exhaust combo huh?
Old 10-14-2006, 07:32 PM   #80
YamilR
YamilR's Avatar
Welcome buddy!
She does have a "pair" right now
YamilR is offline
Old 10-14-2006, 07:54 PM   #81
johnnyfive
johnnyfive's Avatar
just a update after i have had DF210's on my sedan for some time now.
definetly love the ride, and the handeling is wonderful, and the stance is very nice, would have liked the body to sit a little lower to the ground, but what are you going to do?
but the one issue i have had with them is that when i have someone in the back seat the tire deffinetly scrubbs on the plastic inside the wheel well, not a big enough issue for me to do any cutting, but it is deffinetly noticable, and sometimes scares people in the backseat...
but overall i would recomend DF's to anyone that asks me :)
johnnyfive is offline
Old 11-26-2006, 03:53 PM   #82
sillyyaris
Drives: 06 Yaris S
I just got some Tanabe NF210 for my sedan and my friend and I have already installed the rears. We're having problems installing the front. I was wondering how tight the nut is on top the nut that is compressing the spring? We can't loosen it or nudge it. We're even tried holding it down with an allen but the nut still wont move. Any suggestions?
sillyyaris is offline
Old 11-26-2006, 05:33 PM   #83
mrrock
Drives: yaris 2dr hatch
any feedback on the TRD or the Eibach springs compared to the above
mrrock is offline
Old 11-26-2006, 05:36 PM   #84
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
I worked at the damn thing for prob 20mins... but then again I dont have the best tools and I was working with a spot light; If you where to take off all the plastic pieces around the windshield wipers I bet it wouldnt make things easier.
will work for parts
vodkalush is offline
Old 11-26-2006, 05:57 PM   #85
YamilR
YamilR's Avatar
If I remember right Theres only 2 pieces plus the wipers
YamilR is offline
Old 11-26-2006, 06:22 PM   #86
ChinoCharles
Drives: LB
The TRD springs are nice... they aren't quite as low as, say, the NF's, but they still provide an ample drop. The shocks drastically change the handling. Say goodbye to any hopes of a smooth ride, say hello to cornering 90 degrees at 30-40 MPH. Fun stuff.
ChinoCharles is offline
Old 11-26-2006, 07:29 PM   #87
the_saint
50% borikén
the_saint's Avatar
Drives: 06 Mazda5, 90 240sx
You do have the spring compressed right? If not, you NEED to compress the spring before removing the upper strut mount from the strut.
Just remove the strut and spring together and take it to a NAPA or some other autoparts store that has a strut spring comperssor, or maybe a shop can do it for you. Either should charge you around $40 per strut to R&R the spring.
'06+ Toyota bB
Garson - D.A.D. aero
Zuenglein Dolci wheels
the_saint is offline
Old 12-04-2006, 02:07 PM   #88
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
nice DIY
do you guys had to (partially) remove the etire wipper support to get access to the bolt on the shock tower ? (pic is for a hb canadian model)
hystria is offline
Old 12-04-2006, 02:29 PM   #89
hystria
hystria's Avatar
any idea how to remove this 17mm nut ? Can't put the 17mm socket and the allen key in the same time as the nut is "deep"
hystria is offline
Old 12-04-2006, 06:21 PM   #90
Chris07LB
Chris07LB's Avatar
Look at my pictures again.. i didnt remove anything but the plastics out of the way, and a long 17mm box wrench and long allen fit just fine...
It is a bit of a pain to get the right angle, and bite, but after a bunch of baby step turns, its DOES go tight or loose all the way.
Tanabe Strut Tower Bar Install & Review [pics!] Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 04-07-2022 07:46 AM
Springs - Tanabe DF210 or Tein S Tech andylai2k Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 06-10-2007 09:22 PM
Tanabe DF & Strutbar install mcdaddy DIY / Maintenance / Service 18 05-03-2007 09:57 PM
TANABE DF210 SPRINGS AVAILABLE!!! C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 08-05-2006 12:28 AM
Spring Install Price redglare45 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-30-2006 08:32 PM
