Old 04-23-2009, 01:11 AM   #1
Klinton
Klinton's Avatar
Drives: 2009 Yaris sedan Flint Mica
HELP
IM STUCK ON THE CRANK PULLEY INSTALL PLEASE SOMEONE HELP ME I HAVE TO DRIVE TO WORK TOMORROW AND IM STUCK WITH THE CAR IN PIEACES 8157155751 I NEED HELP
205/45/17 Nittos/ KN tyhoon 69 intake
EURO areo muffler / DF 210 Springs
NST 10% Pulley/ 15% tint
600watt rockford punch 12" subs and amp
micro image rocks!
Klinton is offline   Reply With Quote
Old 04-23-2009, 01:14 AM   #2
Creeper
Creeper's Avatar
Drives: Silver 2DLB Yaris
Send a message via AIM to Creeper
what are you stuck with on the install? ahve you checked the diy? need more info if you want us to help
Creeper is offline   Reply With Quote
Old 04-23-2009, 01:16 AM   #3
Klinton
Klinton's Avatar
ok i have the diy open and i cant get the alternator to go forward
micro image rocks!
Old 04-23-2009, 01:20 AM   #4
Klinton
Klinton's Avatar
please guys help me out i need to drive to work tomorrow and this bad boy needs to be in one peace
micro image rocks!
Old 04-23-2009, 01:34 AM   #5
Creeper
Creeper's Avatar
very very VERY gently tap it forward with a rubber mallet. if that dosnt work try taking it off? just make sure you make everything first. maybe try lossening some of the other bolts?
Old 04-23-2009, 01:34 AM   #6
Klinton
Klinton's Avatar
please anyone who can help im freakin
micro image rocks!
Old 04-23-2009, 01:34 AM   #7
Creeper
Creeper's Avatar
or if nothen else put it abck together and save the install for when you have more time
Old 04-23-2009, 01:38 AM   #8
Klinton
Klinton's Avatar
i have time i think i may have broke something and i just want to put it on and then work what i may have broke
micro image rocks!
Old 04-23-2009, 02:18 AM   #9
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Were you able to loosen the lower alternator bolt? That one is a bitch to loosen.
Old 04-23-2009, 02:24 AM   #10
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
When I did mine I didn't bother moving the alternator forward to release tension on the belt, I just removed the crank pulley with the tension on it, and installed the new pulley.
I have the underdrive pulley so I had to pull the alternator forward towards the bumper to increase the belt tension, which was easy.
If you have just the lightweight pulley I don't know if that way will work since the diameter is the same, but it may! I'd be worried about cross threading the crank bolt since you might have too much tension on the pulley and it may not seat straight.
Old 04-23-2009, 12:55 PM   #11
What happened to Klinton? Did he get it fixed? I'm just reading this, and I can't tell what was "broken" exactly.
Old 04-23-2009, 07:38 PM   #12
ddongbap
ZOMGGGG HELPPPPPPPP
Old 04-23-2009, 11:02 PM   #13
Klinton
Klinton's Avatar
i broke my vvti cord to the engine but i got the pulley in and now my car is sitting at toyota and may bot be fixed till monday saddly
micro image rocks!
Old 04-27-2009, 11:46 AM   #14
GeneralDon7
Drives: Yaris Sedan
May be a dumb question but whats a VVTi cord
GeneralDon7 is offline   Reply With Quote
Old 04-27-2009, 04:27 PM   #15
gwasabi
Drives: 07 Blazing Blue LB
I just used a pry bar and gently levered it forward. It didn't take take that much force to bring it forward honeslty. like i coulda put the force of two finger to bring the alternator forward with the pry bar hahaha
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
