Old 11-19-2009, 07:32 PM   #1
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Looking to borrow spring compressors
Hey there South Bay Yaris owners Does anyone have a set of spring compressors I could borrow over the weekend?
Old 11-19-2009, 07:45 PM   #2
supmet
Drives: 2007 4 Door Yaris
I've heard auto zone will lend them with a deposit.. I'd check other local auto parts stores too if you can't find one on here
Old 11-19-2009, 08:05 PM   #3
coffiend
coffiend's Avatar
Drives: 08 Black LB
I rented mine from oreilleys.
$50 deposit with 100% refund when returned.
Didn't Matter how long I kept it either
Old 11-19-2009, 09:09 PM   #4
MadMax
MadMax's Avatar
Or use ratchet straps...
Old 11-19-2009, 09:28 PM   #5
1NZYaris1
1NZYaris1's Avatar
now that is thinking outside the square
Old 11-19-2009, 09:56 PM   #6
YarisSedan
Drives: 08 Yaris Sedan
I can loan you mine. Id do same as kragens just give me 40 bucks and ill return it once you return the spring compressors.
Let me know so i can bring them home so u can come pick them up.
Old 11-20-2009, 02:30 AM   #7
superskunk'd
EAT, SLEEP, DRINK NISMO!
superskunk'd's Avatar
Drives: '07 Nissan Versa S Hatchback
i would recommend using some sort of air gun when you go to compress the springs, makes things so much easier and faster... but yeah just hit up kragen, or autozone $50 is all takes... and its refundable...
superskunk'd is offline   Reply With Quote
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 09:47 AM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 06:02 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 11:11 AM
Track Suspension id3379 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 85 06-11-2009 06:59 PM
Suspension install: Spring Compressors? Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 09-18-2007 11:59 PM
