Old 07-05-2010, 04:25 PM   #1
brg88tx
Drives: 07 Yaris Sedan, Auto
good way to guestimate your mpg using the digital gas gauge
in the short time i've owned my yaris sedan i have figured that the first bar is good for about 75 miles, then about 50 miles per bar thereafter. going by this rough estimate that's 425 miles/11.1 gallons for 38.3 mpg.
you can use this a a rough gauge to see whether you are above or below 38.3 mpg while you are driving around. for example, when you are at about half a tank if you have over 225 miles when the fifth bar drops, you are above 38.3 mpg approx.
brg88tx is offline   Reply With Quote
Old 07-05-2010, 05:40 PM   #2
brg88tx
sorry, i meant to say if you are at 225 miles when the 4th bar drops you are on pace to beat 38.3 mpg.
Old 07-05-2010, 07:40 PM   #3
daf62757
Nothing beats a Toyota!
daf62757's Avatar
I have found that the last three bars get less than 50 miles. They usually get around 40 miles.
Big Dave
Indianapolis, IN
Old 07-05-2010, 08:48 PM   #4
big lo
big lo's Avatar
Drives: 2007 VIOS
That goes to show ya, that the Yaris is good on gas mileage. And you save a dollar or two in you pocket.
Old 07-06-2010, 12:03 PM   #5
daf62757
daf62757's Avatar
I just wish Toyota would have spent a few more dollars on:
1. better instrument cluster
2. larger gas tank...at least 15 gallons
3. insulation or sound proof material
Big Dave
Indianapolis, IN
Old 07-07-2010, 02:15 PM   #6
brg88tx
well, on my way to work my 4th bar dropped at 224 miles, so i should be just about on pace for a 38 mpg tank. i'll let y'all know how it turns out.
Old 07-09-2010, 06:32 PM   #7
b_hickman11
Drives: 08 Sedan
Then it would cost more than a Corolla.
Old 07-09-2010, 06:33 PM   #8
b_hickman11
Drives: 08 Sedan
Not very accurate way of getting your mpg. I have got up to 120 miles on the first bar before.
Old 07-10-2010, 01:10 AM   #9
Ryude
Drives: 2007 Ford Mustang GT
I don't understand how hard is it to simply use a calculator and divide miles by gallons at the pump.
Ryude is offline   Reply With Quote
Old 07-11-2010, 01:27 PM   #10
daf62757
daf62757's Avatar
I don't think so. It would cut into Toyota's profits but I don't think it would cost more than a Corolla.
Big Dave
Indianapolis, IN
Old 07-11-2010, 05:12 PM   #11
brg88tx
it's not "hard" at all, i simply posted this as a way to guestimate your mileage between fillups without the use of a scanguage or ecometer.
Old 07-12-2010, 02:19 PM   #12
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
I'm usually good for around 70 and if I'm doing bad it's around the high 60s. I also noticed every bar was 50 miles after. On the second bar, I would get 120 or if if I drive slower than 65, I'll get more than 130.
KrazyDawg is offline   Reply With Quote
SO I RAN OUT OF GAS THE OTHER DAY ROCKLAND TOYOTA General Yaris / Vitz Discussion 76 10-23-2008 03:02 PM
Single DIN Digital Gauge Cluster Galavoxx Performance Modifications 11 12-29-2006 04:09 PM
