#1 |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
13 inch?
i dont know if this has been asked before but i did a search (13 inch) and didnt get any hits.
i was wondering if it would be possible to get 13inch(175) winter tires and put them on 13inch rims (with 4x100 bolt pattern) and put them on a yaris. how badly will this mess up my speedo and/or my entire car? my car has stock 15" alloys on it now, are 13" too big of a difference? are 13" just a bad idea all together? let me know what you think
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
As long as you run proper tire sizing (175/70/13), it won't mess up your speedo. But it will be hard to find 13's that will clear the Yaris caliper without some spacers. I would suggest going for 14's, which still may require some spacers depending on the wheel.
#3 |
lol, thanks, i didnt even think about that. 14's it will be then. i wanted to have as much space in the wheel gap as possible cuz my 15's build up alot of snow and slush and it makes them even worse.
#4 | |
#5 | |
Start another Oil Thread!
i fit 13X9 4" backspace Bassett Racing wheels on my MR2 spyder with no spacers and i'm guessing my front caliper/rotor combo is no smaller than the yaris.
you nailed it sir.
#6 |
I tried a set of 12" Subaru Justy steel wheels as an experiment, and they were less than 1/2" shy of clearing the caliper, so I would think that 13" steelies would be OK.
#7 |
13's fit, just hard to find a set that'll clear yaris calipers....
you're better off finding some 14" wheels/tires used on kijiji since just about anything with a 4x100 pattern will fit the yaris's small hub center... tire size be damned...you can run almost any available 14", aside from a 195-65-14 and still be fine in the winter
#8 | |
#9 |
#10 |
but 185-65-14 and 205-65-14 will fit?
#11 |
205/65/14 will be WAY too tall. 185/65/14 is fine.
#12 |
Some education Jeff.
The middle number (65) represents the sidewall height as a percentage of width. 185/65 = sidewall of ~121mm 205/65 = sidewall of ~133mm
#13 | |
it's a snow tire.. who cares?
but then again, 205 is too wide for a snow tire on a tincan-light yaris
you nailed it sir.
#14 |
lol, i know the middle number was the profile %, it was just the way u said 195-65-14 would not fit, like that certain size was a triangle or square. lol
#15 |
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
FWIW, I have 13x7.5 Lenso's with a 25mm offset as my racing rims for my Echo.
