Old 07-29-2011, 09:05 AM   #1
nickos
Drives: yaris
steering wheel swap over
just wondering if its possible to swap the base model steering wheel over for the leather one with audio controls and if its possible how hard is it and whats involved
thanks
nick
nickos is offline   Reply With Quote
Old 07-29-2011, 09:18 AM   #2
Yes - It is possible and not all that hard to do. I am running a European leather RS one on my Yaris (but without the audio controls). To use the audio controls you will need to also get the airbag that goes with them, since the airbag cover is different.
Here's a video that I put together a while back on removing the steering wheel and clock spring to change the headlight stalk, but in your case you would just need to go as far as removing the airbag and the steering wheel:
http://www.youtube.com/watch?v=LgWSzVeILhc
Old 07-29-2011, 09:23 AM   #3
nickos
Drives: yaris
so its pretty much plug and play? with the different clock spring does that mean that there is additional wiring needed for them to operate
Old 07-29-2011, 09:34 AM   #4
In markets where the audio controls are not offered (like here in the US), you have to change the clockspring to one that has more wires in it for the audio controls. If the audio controls are offered in your area, then you probably already have the correct clockspring to support the audio controls. To use the audio controls you will need to also add the wiring between the steering column and the radio.
Old 07-30-2011, 05:19 AM   #5
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
I know for sure the 2006-2008 scion tC wheel fits,not sure about the clockspring but I am betting it is a direct fit to our column from the tC.
You can pick up fairly cheap an tC steerign wheel from ebay or junkyard and source out the clockspring,worst comes to worse you just end up with the wheel which our airbag bolts up to as well,but no controls.
Old 07-31-2011, 09:27 AM   #6
vdubs4ever
vdubs4ever's Avatar
Drives: Red '08 3 Door
Where could I find an RS wheel, and would it bolt right on
Mors Certa, Hora Incerta, Memento Vivere
vdubs4ever is offline   Reply With Quote
Old 07-31-2011, 10:45 AM   #7
They are not easy to come by - ebay, junkyard, for sale section here. The RS (or TS from Europe) one does just bolt one and the airbag fits perfectly.
Old 08-04-2011, 01:28 AM   #8
rapev-8
Drives: toyota
wow this that was a very good video!!! my question now is on my 2010 can i just buy the cruise control stalk and plug and play?
rapev-8 is offline   Reply With Quote
Old 08-04-2011, 06:55 AM   #9
Yes. If you have a manual transmission, you also need the cruse control clutch switch, but your 2010 is pre-wired for cruise.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Steering wheel swap Maitre_Te_Te Cosmetic Modifications (Exterior/Interior) 2 10-18-2010 12:51 AM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
