#1 |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
How to change radiator fluid/
Well the car is a bit over 110k and I figure it's time to change the radiator fluid, as well as it's starting to get low from evaporating over time ,etc. Is there a writeup or can someone put up a step by step on a proper way to drain the fluid and refill it? Thanks!
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
![]() ![]() ![]() ![]() Drives: '07 Yaris turbo, '11 Juke Join Date: Mar 2007
Page 8 of the cooling section in the factory repair manual. I change mine at 90k.
http://www.cardomain.com/ride/3875996 |
#3 |
Could you please post me a link to the manual? I'm having a hard time finding it, thanks!
#4 |
Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > DIY / Maintenance / Service..............2007 Yaris Factory Repair Manual
That's not a link but it's where to go on this forum. Find that and it will link you to the service manual for the 07. Things haven't changed that much so it should help you out. Did mine not to long ago. if you have any questions shoot me a PM. |
#5 |
![]() ![]() Drives: 2008 5 Speed Sedan Join Date: Jan 2011
thanks for the info, found what I think I need in the manual. does anybody know, does it matter if I use prestone premix (green) vs toyota super long life fluid (pink) ? - no leaks, levels still ok, color is still bright pink. 152,000km
#6 |
Drives: yaris Join Date: Jan 2011
the new green prestone 50/50 premix that works on ANY car ANY cooling system
(says on bottle) will work fine anywhere Toyota red is specified otherwise, stick with Toyota red from the dealer and u cannot go wrong old-school prestone green is NOT recommended |
#7 |
On my ECHO you just opened the radiator drain and take the radiator cap off. Engine is cold! All the coolant the book says is in there came out
Close the drain and fill with 50/50 mix of coolant and water. Start the engine and warm it up until the coolnt level in the radiator goes down. Top up the radiator and rstart. Keep filling it until it doesnt go down anymore. Yaris is the same? |
#8 |
Doing mine....I drained the
1. Radiator 2. Block via the valve on the backside of the engine 3. Overflow tank on the side of the radiator Did I get it all? Nope......Pull the fixture where the bottom radiator hose attaches at the engine behind which is the thermostat. If you easily pry out the thermostat you will see a cavity. That's where the remainder will be. Anyway I caught the fluid and measured comparing to amount required and I got it all. |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 08:18 PM |
| My Oil Change Help Me, Please! | JetfireK | General Yaris / Vitz Discussion | 6 | 01-09-2011 11:25 PM |
| $86.44 for oil change? I feel screwed | behour | General Yaris / Vitz Discussion | 98 | 01-04-2010 08:10 PM |
| MJ dead | 90tsi | Off-topic / Other Cars / Everything else Discussions | 28 | 06-26-2009 03:20 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-08-2006 12:21 AM |
