Old 11-26-2011, 02:05 AM   #1
superfly78209
Drives: 2010 Yaris 5 Dr Blue Grey
DIY ROSTA CRUISE HELP
Ok so I have done everything with this cruise install except for the part that involves the brake switch. Here's the URL: http://www.rostra.com/manuals/250-1873_Form5258B.pdf
I'm finding the brake switch part difficult. Do I take apart the switch and try to solder the wires and then put it back together? Do I cut off the insulation and the blue and black wires and then try to solder directly on to those - soldering is difficult enough without having an end of a wire to solder onto but rather a mid piece and not a lot of room? I am not seeing the best way to go about this whole thing and I dont want to do something stupid and mess up my braking system. Thanks in advance.
Megan Axle Back Exhaust
Pro Dry S Replacement Filter
superfly78209 is offline   Reply With Quote
Old 11-26-2011, 09:42 AM   #2
Wow, installing the Rostra kit is a whole lot of more work than installing the OEM cruise control.
For your brake switch connections, you are basically tapping into the two wires, which feed the brake lights. For those connections in that tight space by the firewall, I would use tap splice connectors, rather than trying to solder under there. The pic below is an example of a tap splice (available at any auto parts or hardware store). You slip the tap splice over the wire, slide your wire to tap to it into the second groove, and squeeze the metal blade with a pair of pliers. The tap splice blade cuts through the two wires' insulation to make the connection.
Old 11-26-2011, 12:06 PM   #3
superfly78209
Great Idea. I'll go buy two right now. Also, there are some wires left over from the first bank of the cruise box. I guess they don't go anywhere.
Old 11-26-2011, 12:14 PM   #4
superfly78209
Also, there are two green wires on the brake switch going to the same pin on the connector. I'm assuming they both carry the same signal so I'll just try to tap one of them
Old 11-26-2011, 12:32 PM   #5
Correct
Old 11-26-2011, 02:37 PM   #6
superfly78209
Have another question. There's a black lever that must be released in order to insert wires into the small wire box thing. I released it but every time I insert a wire and close the lever, the wire still manages to come out. Maybe the lever comes all the way out? Or the wire isn't thick enough? what do you think?
Old 11-26-2011, 02:58 PM   #7
Make sure you are sticking the wire on the correct side of the piece of spring metal that the lever presses on. Depending on the type of spring terminal, some you stick the wire on the lever side, others on the opposite side.
Old 11-26-2011, 05:02 PM   #8
superfly78209
Rostra sucks A$$. You know they didn't even include the spring connector. Luckily my dealership gave me some for free. All I had was bare wire to stick in the connector. I should be done here in an hour and have to solder on the connectors to the bare wire. Lets hope this damn thing actually works.
Old 11-26-2011, 05:49 PM   #9
thepartsmancometh
Drives: '08 LB, '07 WRX
Mine came with everything needed, but that was a few years ago. our rostra unit has been flawless since 2008. (installed prior to seeing this site)
thepartsmancometh is offline   Reply With Quote
Old 11-26-2011, 07:40 PM   #10
superfly78209
Ok so after visiting the dealership twice and getting free parts (pins) and some free help.. everything is hooked up. But, my unit does not have power for some reason. I have double checked all connections and everything is fine. I guess I will be calling them on Monday.
Old 11-26-2011, 08:01 PM   #11
Out of curiosity, what made you go for the Rostra aftermarket system instead of using the OEM cruise control?
Old 11-27-2011, 02:51 AM   #12
superfly78209
Well I have an 07. There are a lot of parts I would have to buy (not able to just buy the cruise stick like the 08s) and I would also have to remove the air bag and etc. I figured it would have been easier to go with the Rostra. I've heard good things but the new "universal" kit they have put out for the 06-current Yaris cars doesn't seem to be too great.
Old 11-27-2011, 03:39 AM   #13
mr_miles
Drives: 2013 Yaris
i didn't know for an 08 all you needed was the OEM cuise stalk....I should swap to it. My Rostra works, but occasionally it slows down instead of accelerating.
Old 11-27-2011, 09:56 AM   #14
For an 07 you would need:
Cruise Stalk with wire and mounting screws
ECM connector Pin
Two steering wheel connector D3 pins
Optional - My Cruise Control Indicator Module (which provides a visual indicator that cruise is on for pre-09 Yaris, which don't have the indicator in the cluster).
From the dealer the stalk, wire, mounting screws and pins would run about $150. I sell the stalk with wiring and screws for $40, The ECM pin for $5, The pair of connector D3 pins for $5, and my indicator module for $25. So, for an 06-08 Yaris, OEM cruise can be as little as $50.
You are correct on having to pop off the airbag, but that is really not as daunting as it sounds. My DIY shows all of the details of the OEM install:
http://www.yarisworld.com/forums/showthread.php?t=33750
Old 12-01-2011, 07:12 PM   #15
superfly78209
lol.. well hindsight is 20/20. I guess I should maybe consider going with the $50 option.. If you go to the Rostra instructions for my car. It has me grab power out of a pin under the dash. Since I haven't been getting power to my cruise, I have been debating if there is power to that specific pin. I took my voltmeter to the pin today.. no power. Rostra's instructions direct me towards putting a pin in a hole that is unpowered by the stock wiring harness. WTF? Anyone have any ideas. thanks.
Old 12-01-2011, 08:52 PM   #16
In connector 4B of the under hood fuse panel, Pin 9 (red wire) should be ignition switched power. Pin 27 (pink wire to the right of it), is also ignition switched power.
Old 12-02-2011, 03:31 PM   #17
superfly78209
K, I'll go with the pink one.. Any suggestions on how to solder to the pink wire? The harness is very tight and I have no idea how I'm going to get the wire loose enough to actually be able to get my soldering iron up under there.
Old 12-02-2011, 04:25 PM   #18
I suggest using a tap splice. Unless you take the dash off, it is almost impossible to safely solder up there.
DIY: 2006-2011 Yaris OEM Cruise Control Complete Installation CTScott DIY / Maintenance / Service 172 10-27-2025 03:04 PM
DIY Cruise Control for 2012 Yaris - Good News! CTScott Third Gen Yaris General Discussion 305 10-27-2025 02:52 PM
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
FS: DIY Cruise Control Pin Kits CTScott Items for Sale by private party 14 07-30-2012 01:44 AM
