Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 03-20-2012, 07:14 AM   #1
aksledneckm1
Drives: 2008 Yaris S
Courtesy lights
I have a '08 Yaris S and the map lights used to gradually dim after exiting the car or brighten when opening the door. That feature no longer works. However, the map lights work manually, and so does the dome light. Could the cause be the module for the interior lighting? It's not the door switch or a fuse otherwise the other functions would be affected.
aksledneckm1 is offline   Reply With Quote
Old 03-20-2012, 09:04 AM   #2
It could be. That function is controlled by the body ECU when the switch is in door mode. You do see the door ajar light come on in the cluster, correct?
Old 03-21-2012, 05:23 AM   #3
aksledneckm1
Yes it does light up with door open. That's the first thing I looked at and tested a few times.
Feeler: Depo Projector Lights w/Halos (incl. HIDs) Betrivent Items for Sale by private party 21 12-17-2012 12:54 AM
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 05:13 PM
How to turn on the running lights and fog lights @ same timewhile/headlights off ...? Moratiya DIY / Maintenance / Service 8 12-11-2010 06:40 PM
Taillights, signal lights, parking lights stop working jamal1984 DIY / Maintenance / Service 2 10-13-2010 10:17 AM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 07:54 AM
