Old 09-04-2012, 08:54 PM   #1
Roger2012Yaris
Drives: 2012 Yaris LE
Antenna wire; Canadian LE model
Hello.
New here; sorry if this has been discussed already...
I've swapped out the factory radio and speakers. All was going great until I had a look at the antenna plug... yeesh! This is definatley not a Motorola nor is it one of those plugs with the two round pins. Instead, this is a square plug with a few contact points on each side. I've tried my local dealership and audio shops; no one's got an adapter!
I decided to take matters into my own hands and purchased a Motorola plug. I then cut the antenna connector in the car, being careful to leave enough wire to splice the oem back in along with my Motorola. This is where the next surprise popped up. Counting the shield, there are five wires to connect - the shield, red and black (for amplification, I think) and then two more wires within the shielded sleeve. This is where I expected a single wire but ended up with green and yellow.
I did see a post where someone found an adapter on eBay, but this doesn't look like what I need.
Uh... help?!?!?!
Thanks.
Roger
Roger2012Yaris is offline   Reply With Quote
Scion XD LED mirror install pics aplenty enviri DIY / Maintenance / Service 76 07-21-2019 03:10 PM
Most Reliable Makes of 2010 2007yariz General Yaris / Vitz Discussion 16 12-02-2010 04:37 PM
DIY: Installing XM Radio with SureConnect antenna adapter The Marshall DIY / Maintenance / Service 0 07-11-2009 10:57 AM
Yaris from New Zealand model - some differences to Canadian RS Yaris model Super_BQ General Yaris / Vitz Discussion 0 07-23-2007 03:54 AM
Routing XM Antenna Wire blacksan In Car Entertainment + Electronics (audio / video / alarm) 17 05-11-2007 12:56 AM
