Old 01-02-2013, 11:17 PM   #1
kaymm
kaymm's Avatar
Drives: Yaris Liftback 3dr (Silver)
LED Flasher relay
Hi
I picked up one of these flasher relays for my 07 Yaris HB. I plan to replace the back turn signal lights with LED. Do I have to replace change every single turn signal light to LED or can I just do the back first? What happens when you use LED + incandescent bulbs?
http://www.alibaba.com/product-gs/57...her_Relay.html
07 Yaris LB 3dr
Silver Mica
5sp manual shift
kaymm is offline   Reply With Quote
Old 01-02-2013, 11:43 PM   #2
That relay says that it is rated for 150W, so it would not be an issue to run it with all of your incandescent bulbs or with a mix of LEDs and incandescents.
The reason why you can't run LEDs with the OEM on is that it relies on the current draw of the bulbs for the timing circuit. If you change that total current draw it goes into a hyper-flash mode, which is supposed to let you know that you have a dead bulb.
The aftermarket LED rated ones simply eliminate that feature.
Old 01-02-2013, 11:49 PM   #3
kaymm
kaymm's Avatar
I haven't looked yet but do you know where the stock flasher relay is? Should be a simple swap right?
I tried putting LED's before and they did blink fast, so I got some resistors but somehow that didn't work. I probably didn't tap them into the right wires. Then I read a simpler method is to replace the relay. So I'm hoping this does it. Thanks!
07 Yaris LB 3dr
Silver Mica
5sp manual shift
Old 01-03-2013, 12:02 AM   #4
The stock one is behind the little storage cup on the lower left. It is easy to swap.
Old 01-06-2013, 02:00 AM   #5
kaymm
kaymm's Avatar
It works! No hyper/fast blinking. Much easier than using resistors.
The one on the left was purchased from eBay. It was super hard to remove the stock one for the first time. Had to yank it pretty hard. The LED flasher relay had these long black tabs on the sides that had to be bent inorder to go in properly. No biggie. Thanks!
07 Yaris LB 3dr
Silver Mica
5sp manual shift
Old 06-24-2022, 03:37 AM   #6
irakli_86
Drives: Yaris MK2
Is there no genuine Toyota relay part number for this purpose instead of the aftermarket one ?
irakli_86 is offline   Reply With Quote
DIY: Adding LED turn arrows to side mirrors my2sense DIY / Maintenance / Service 10 05-28-2012 02:16 AM
DIY LED Strip under the door panel charleschia1986 DIY / Maintenance / Service 19 11-05-2011 07:49 PM
Who's got an LED flasher module? Lil Abner Cosmetic Modifications (Exterior/Interior) 7 08-07-2011 11:57 AM
Relay Wiring for DIY LED Daytime Running Lights (DRL) zuberio DIY / Maintenance / Service 20 07-07-2011 08:02 PM
Did I just fry my flasher relay? jon@swoveland.com DIY / Maintenance / Service 8 06-19-2010 11:26 PM
