Old 02-07-2013, 11:45 AM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
My new grille blocks for my sedan...
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 02-07-2013, 01:24 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
reason for using?
Old 02-07-2013, 03:30 PM   #3
Nice! Can hardly tell it's there.
fnkngrv, it makes winter/cold weather driving much better. Much shorter warm up times, and protects the rad from salt and stones.
Old 02-07-2013, 03:39 PM   #4
fnkngrv
fnkngrv's Avatar
so wtb then?
Old 02-07-2013, 03:42 PM   #5
malibuguy
Obsessed with 1.5L
Yes faster warmup and less aero drag from the air being slowed down going thru the rad. I normally would of ran a smaller opening but I figure this will work for now. My old xB my left over opening was about half of this.
-96 Tercel 4dr
Old 02-07-2013, 04:08 PM   #6
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Looks great! I'm curious about engine temps. Blocking off both top and bottom inlets, does it ever get too hot? (overheat)
Old 02-07-2013, 04:12 PM   #7
I run the lower completely blocked off and I never run into issue until about 5°C above freezing.
I have a mechanical temp gauge in the block, so I know the exact water temp. Normal with no block it runs at about 180-190°F. With the block it runs 190-210 on the hwy. But that's only after about 20-30min. If it gets any hotter I just turn the heater on and crack the windows and the temps come down.
Old 02-07-2013, 10:40 PM   #8
malibuguy
Obsessed with 1.5L
i havent hooked up my scangauge to verify temps yet. but i figured my xB was fine even during the summer with a smaller opening, then mine should be fine...especially now
i probably should actually install the scangauge in this car...
-96 Tercel 4dr
Old 02-08-2013, 07:45 AM   #9
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I've been running a full grill block in my cavalier for around 4 years now. I know, different car, different challenges. I started with the plexiglass cover though I will say it gets pretty scuffed over time. I painted my cover and did that for a while until I fiberglassed it off. the end product came out pretty well though youtube flamed me pretty hard over it.
Depending on how the car gets its cooling, blocking off the grill doesn't matter at all. My cavalier actually got 90% of its cooling from underneath. Not sure how the airflow in the yaris works yet.
It does look good and very incognito
Old 02-08-2013, 08:13 AM   #10
malibuguy
Obsessed with 1.5L
Its got a factory tray under the bumper. So its sourcing all the cooling air from up front
-96 Tercel 4dr
Old 02-08-2013, 11:22 AM   #11
Hershey
Very nice .
Old 02-24-2013, 05:10 PM   #12
dragoonmc
Drives: 07 hatchback
I did a very similar thing except I used black aluminum which means it just looks like one big hole to me
dragoonmc is offline   Reply With Quote
Old 02-26-2013, 05:19 PM   #13
STC
"LibertyRides!"
STC's Avatar
Nice! Aesthetically appealing!
Cheers!
~ Mark ~
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
2007 Yaris Sedan Front Grille Stacieee Cosmetic Modifications (Exterior/Interior) 1 05-29-2012 09:48 PM
Is '09 & '10 yaris sedan grille compatible? jizan DIY / Maintenance / Service 1 03-27-2012 01:40 PM
09 sedan grille Francos Yaris General Yaris / Vitz Discussion 17 11-23-2010 04:28 PM
