#1 |
![]() Drives: Yaris NSP90 1.33 TTE Join Date: Jan 2010
P2112 Throttle Actuator Control System - Stuck Closed
My Yaris throttle feels a bit like on and off for a while.
After restarting (pushing the clutch at a traffic light) (Yaris NSP90 1NRFE with automatic start-stop system) the MIL light burns. ![]() This is my Techstream screenshot. I've cleaned the valve (was a bit clogged), cleared the error code and aligned the throttle body with Techdoc documents. The light is still off after a few months, but the throttle feels still a bit on-off. The car is only 20.000 miles old, and the valve is (after cleaning) brand new. ![]() ![]() ![]() What's next? Replacing the TB? Reprogramming my ECU? |
If you have a legal subscription to TechStream, you can load the updated ECM firmware. I would start with that, or if you car is still under warranty, bring it in to the dealer to see if they will do the TSB and change the TB and upgrade the firmware.
#3 |
The car is almost 5 years old now.
I've downloaded all the ECU files, but I've never updated my ECU before.
#4 |
OK. Try the update then. The process is pretty simple with Techstream.
| ACRONYM thread | Shroomster | Off-topic / Other Cars / Everything else Discussions | 45 | 02-15-2025 10:30 PM |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
| Throttle System? | ExocetCom | General Yaris / Vitz Discussion | 10 | 08-17-2007 08:10 PM |
| toyotafest 2007 | esquiva | Photo-Video-Media Gallery | 36 | 05-15-2007 12:03 PM |
