Old 04-11-2015, 09:20 AM   #1
mnieves79
Drives: 2008 Yaris Sedan
Brake adjuster loosening while driving?
Hello,
I've had brake issues with my 2008 Yaris sedan for a few years now. Last two times I've taken it in to a shop. Problem is with the adjuster on the right side drum. Rather than self-adjusting it is self-loosening.
I've had the adjuster replaced 3 times with new aftermarket parts. Problem persists. Not sure what else to try.
Any suggestions? I do not want to keep trowing money at this problem. This is the vehicle my wife uses to get to work and take our daughter to kindergarden. I need a permanent fix. Do not want to risk our family's life.
Thanks,
Martin
mnieves79 is offline   Reply With Quote
Old 04-11-2015, 09:29 AM   #2
maybe you're putting the adjuster in the wrong way. one way will self tighten the other will loosen....if it can be backwards.
Old 04-11-2015, 04:24 PM   #3
the_teach
Toyota Lover
the_teach's Avatar
Drives: 2009 Toyota Yaris Sedan
You likely have a problem with the adjuster arm incorrectly installed or adjuster incorrectly installed. do a search to get an image of the rear-brake assembly to verify it yourself.
'09 Flint Mica Sedan
345,000km and counting
the_teach is offline   Reply With Quote
The brake story: frequent disk warpage Lux DIY / Maintenance / Service 20 11-01-2014 12:25 PM
Drum brake problem. theb DIY / Maintenance / Service 4 04-23-2014 02:04 AM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
