Old 02-06-2016, 09:24 PM   #1
rabbito
rabbito's Avatar
Catz Headlight Bulb
these are Catz, japanese brand headlight bulb that i got for about $30..its getting really popular in asia so i gave it a try..gives a slight blue tint around the headlight reflector(no shit cause bulb is blue) and way brighter than stock bulb...if you can burn money, go ahead and get projector xenons :)
Sent from my ASUS_Z00AD using Tapatalk
Cosmetic: Toyota red emblem
Old 02-06-2016, 11:52 PM   #2
sickpuppy1
Drives: 2010 Yaris Sedan
one bulb?!
Old 02-08-2016, 08:27 PM   #3
rabbito
rabbito's Avatar
no, two...-_-
Old 02-08-2016, 10:34 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Hope they last cos it's a pain to install on hb Yaris
Also post pics of bulb out of box and when installed.
Sent from my ONE A2005 using Tapatalk
Old 02-09-2016, 01:44 AM   #5
rabbito
rabbito's Avatar
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 12:34 PM
Headlight bulb change....more to it than meets the eye... Yarflana DIY / Maintenance / Service 0 03-24-2013 09:56 PM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 09:58 AM
Headlight question bulb sizes.. Darwin84020 DIY / Maintenance / Service 1 12-21-2010 11:00 PM
DIY - A EASY&FAST way to change headlight bulb ALLBLACK DIY / Maintenance / Service 0 09-18-2010 02:40 AM
