Old 05-18-2017, 08:11 PM   #1
Coreywall
Drives: 07 yaris auto 5 door hatchback
ecu problems.
hey guys i've got an 07 yaris hatchback, automatic. my headlights didn't work and it turned out to be the ecu cause the headlight relay is in the computer. so there is a few different computers. the part number for the computer is 89661-52F01. I should also mention im in Canada, the car was made in japan for the Canadian market and I talked with Toyota and they said that the computer number 52F00 was superseded by 52F01 and both should work but it would be best to use the newer number. in my search for this thing if found out that there is 4 different numbers and I was wondering if any of you might know the difference between the different numbers. im assuming it has to do with the transmission but im not sure. any help would be much appreciated.
Coreywall is offline   Reply With Quote
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 10:40 AM
ECU Extension Harness (1st Gen Echo/Vitz) ITA Performance Modifications 4 08-24-2018 04:09 PM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 02:50 AM
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 04:47 PM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 10:56 AM
