Old 11-16-2017, 12:08 PM   #1
AndreS123
Drives: 2012 Yaris L, 2017 Yaris L
Accidental arc to ground, help!
I was in a rush today, had a dead alternator that I was trying to change out quickly & forgot to disconnect the battery. (Big bonehead mistake). I heard a pop when it happened too.... But can't figure out what went.
I got the alternator swapped and the car now starts, but.... lights are on on the dash (abs, tc, brake, airbag...)
No power steering, no locks, etc....
Seems like a main relay or fuse, but fuses look good.
Any suggestions? Where to start?
AndreS123 is offline   Reply With Quote
Old 11-16-2017, 12:44 PM   #2
Check the fusible link located just behind the positive terminal ibn the main positive wire. It may have popped
Old 11-16-2017, 02:24 PM   #3
AndreS123
Yep! Found it! Now I just need a new one is this a dealer only part?
Old 11-22-2017, 02:43 PM   #4
AndreS123
I used a standard fusible link(14g wire type) as a temporary fix, just pushed an all through the cable, put the link into it, taped it up, and put the other end on the battery side... Car runs & everything works. Bought a new fuse thing from the stealership, ~$25.
Old 11-23-2017, 02:28 PM   #5
you probably could have gotten one way cheaper at an auto wreckers
Old 12-02-2017, 02:10 PM   #6
Motzking1
Motzking1's Avatar
Drives: 47 2013 yaris l hatchbacks
Hope this helps.
Sent from my Nexus 6 using Tapatalk
Motzking1 is offline   Reply With Quote
Old 12-02-2017, 02:12 PM   #7
Motzking1
Motzking1's Avatar
Fusible link block assembly.
Increased ground clearance between 2008 and 2010 Sedan unclenefeesa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 01-17-2013 06:49 AM
rare arc super induction box , oil cap , rad cap blacksandiegovitz Items for Sale by private party 7 03-28-2012 02:43 PM
Stereo Ground Wire xiii In Car Entertainment + Electronics (audio / video / alarm) 2 12-22-2011 08:00 AM
Aux in ground loop noise xavierq In Car Entertainment + Electronics (audio / video / alarm) 14 06-10-2011 03:47 PM
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 02:56 PM
