#1 |
![]() ![]() Drives: 2017 Yaris SE Blue Streak Join Date: Aug 2017
Exhaust leak at 20k km
Has anyone else experienced an exhaust leak coming out about the driver's door with low milage?
I'm noticing mid range rpm it goes out the side, instead of the rear Sent from my SM-G930W8 using Tapatalk Last edited by logoris; 05-25-2018 at 10:05 PM. |
Will be taking it into the stealership will let everyone know
Sent from my SM-G930W8 using Tapatalk |
#3 |
![]() ![]() Drives: 2012 Black sand pearl <3 Join Date: Feb 2018
I wonder if it was poor installation and not a faulty part.
#4 |
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
probably a bad gasket or somethings not tight, when did it stop, did you bring it into a shop recently.
#5 |
It's been going about 2k km now. I didn't notice any event that would cause it to change
#6 | |
You’ll find the exhaust leak pretty quickly. Tester via toyotaworld or we forum i found it on, standard procedure as they are the same engine and design as a 2010 |
#7 |
Ok dealers have said they can hear it but there is nothing to fix.
Maybe I'm wrong does anyone else get a deafening drone from the factory exhaust 3000+rpm underload Sent from my SM-G930W8 using Tapatalk Toyota Canada says that unless a dealer says there is a problem they will not cover it Last edited by logoris; 06-28-2018 at 03:38 PM. |
| Newbie with an exhaust leak on his '06 Yaris | ToYarta | DIY / Maintenance / Service | 49 | 01-03-2019 01:50 PM |
| My Echo Exhaust Leak in Front ? | frank2005 | General Yaris / Vitz Discussion | 8 | 08-02-2017 09:52 PM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 09:02 AM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Enkei's and Dunlops + Medalion Touring Exhaust | 2manywheels | Items for Sale by private party | 40 | 04-04-2011 06:01 PM |
