Old 06-25-2018, 01:13 AM   #1
hmsailor
Drives: 2015 yaris hatchback
oil change interval
service manager said synthetic requires 10k intervals at the most. last oil and filter change was 17k miles. im at 22k now and the maintenance light came on. do I need to change it at 5k miles,
hmsailor is offline   Reply With Quote
Old 06-25-2018, 02:32 AM   #2
scylla
Drives: 2015 Yaris L
10k at most is right, IF you are driving all highway miles. With mixed driving you should do it at 5K.
With Walmart synthetic oil and a good filter it is pretty cheap.
scylla is offline   Reply With Quote
Old 06-25-2018, 03:53 AM   #3
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
For my normal use Yarii I do it every 5000 miles. My taxi one it gets stretched out to 6000 miles because I drive it so damn much. Synthetic oil only for all of my stuff.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 06-25-2018, 12:14 PM   #4
hmsailor
K. Thanks.
Old 06-25-2018, 07:55 PM   #5
Oil change interval is required by the manufacturer depending on your location. Most of the time, it is the filter that isn't able to hold more than you want.
I would not risk long interval change within warranty period. Otherwise, I've been doing 8k miles interval without issues for the past 6-7years. No sign of oil consumption.
Otherwise, I've always had 3k miles synthetic oil change intervals for the first 3-4 years I've owned the car.
Now my car is beat up, I change it once a year, mileage independent.
Sent from my SM-G930W8 using Tapatalk
Old 06-25-2018, 10:49 PM   #6
JDJanitor
Drives: 2016 yaris
I just got my Yaris, a 2016 it had 43k on it.
I changed the oil to super tech full synthetic, and a fram ultra filter At 45k,
I will change the oil again at 50k, same filter, and then 55k and change the oil and filter.
Fram ultra are rated for 20k miles. So I feel 10-15k miles in less than a year will be ok.
You could run the oil of your choice for 8k to 10k miles, can send your oil for an analysis that will tell you the condition of your oil and the levels of the wear metals and the company will recommend for you to go further the next oil change or less on the next oil change depending on what they find. Some oils truly can go much farther than others.
The thing that concerns me, is that there were quite a few Toyota engines that got carbon and sludge buildup around the oil ring on the piston and began consuming oil it seems like a relatively common thing, and I personally believe it may be due to Extended oil change intervals
Sent from my moto x4 using Tapatalk
JDJanitor is offline   Reply With Quote
Old 07-02-2018, 11:08 AM   #7
hmsailor
3 quarts of oil?
Old 07-02-2018, 11:15 AM   #8
Originally Posted by hmsailor View Post
3 quarts of oil?
4qt!
Old 07-02-2018, 09:51 PM   #9
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
You should also change the manual or automatic transmission fluid every 40K or so miles to maximize the chances of your transmission lasting hundreds of thousands of clean-shifting miles without issues. I changed my manual transmission fluid at 35K (3.5 years from date of it hitting dealer lot for sale) with the same Toyota OEM replacement fluid & could immediately tell the difference in shifting quality. Gotta keep the transmission happy, as it is one of the most likely components to fail or have issues if it isn't taken care of.
Kalispel is offline   Reply With Quote
Old 07-04-2018, 12:54 PM   #10
91mustang
Drives: Charcoal 2012 Yaris SE 5 Speed
Hey Kalispel,
What kind of fluid did you use for manual gearbox change? I'm sure the manual states it, but i don't recall the capacity either. Any opinion on using redline or amsoil fluids?
91mustang is offline   Reply With Quote
Oil change interval David C DIY / Maintenance / Service 26 07-06-2023 04:32 PM
my first DIY oil change since 1988 justanotherdrunk DIY / Maintenance / Service 15 03-01-2017 11:58 AM
Should I Change My Oil After 1300 Miles? bronsin DIY / Maintenance / Service 3 10-28-2016 02:25 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 05:27 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
