09-25-2020, 10:14 AM | #1 |
Drives: 2009 Base Hatch 2 Dr Auto Join Date: Dec 2008
Maintenance not in the owners manual
Battery corrosion. Some batteries corrode some don’t. It’s caused by battery acid gas leaking around the terminals. Whenever I get a car first thing I do is grease the terminals with wheel bearing grease. But you still have to check periodically unchecked you can have a real mess and a no start. If there is corrosion baking soda mixed in a pot of hot water and a wire brush will scrub it away. Then you can reapply the wheel bearing grease
Synthetic Oil: Its All In Your Head |
09-25-2020, 04:42 PM | #2 |
Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
Yup. I've seen a lot of nasty looking battery terminals. Definitely should be part of the routine maintenance schedule.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ |
09-25-2020, 08:18 PM | #3 |
Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
Fluid Film is good for the batt terminals.
09-25-2020, 11:52 PM | #4 |
What’s that?
Similar Threads | ||||
Owner's / Service Manual | tyrone_yaris | General Yaris / Vitz Discussion | 3 | 01-30-2012 12:02 AM |
For Sale: 1993 Honda Civic Si 2dr Hatchback 5sp Manual | Effizienz | Cars for Sale by private party | 9 | 01-17-2012 11:08 AM |
Warranty Information for US Yaris Owners | AdeJong 03 | General Yaris / Vitz Discussion | 4 | 09-19-2009 10:14 PM |
Yaris 2002 - Owner's Manual | abhinav_kr | DIY / Maintenance / Service | 0 | 08-20-2009 11:49 AM |
C54 MANUAL TRANSAXLE service manual needed | ricepower | DIY / Maintenance / Service | 1 | 08-29-2007 07:24 AM |
