Old 07-17-2021, 02:06 PM   #1
bsgray2900
Drives: Blue '08 Yaris 3 Door Hatch
Exclamation HELP! Rear Right Tire Leaning In
I have a '08 Yaris 2 door Hatch and just recently my rear right (passenger) tire is leaning in at the top with unintentional negative camber and I've been trying so hard to fix it. Everytime I make a turn (mainly right turns is when it makes noises) It will make a loud grinding noise and I know it's my tire rubbing against my shock. I replaced the shock/strut because that was busted and leaking but it still did not fix my leaning tire problem. These cars don't seem to have control arms in the rear and I've been banging my head trying to figure out what's the problem. I've been trying to drive it carefully but the road that goes up to my house has a few potholes in it and I'm not sure how to fix it, any help would be greatly appreciated and if need be I can provide pictures.
bsgray2900 is offline   Reply With Quote
Old 07-17-2021, 04:01 PM   #2
Rear hub bearing probably shot. When you raised the car to replace the shock you had the opportunity to see if you could feel the wheel wiggle top to bottom, side to side.
Old 07-17-2021, 04:36 PM   #3
bsgray2900
Unhappy
I'm not too sure. There's a bit of play when I rock the wheel a bit, but I'm not entirely certain given the simplicity of this rear axle assembly. I've added some pictures and maybe it might clear some things up a bit, the new shock is fine, the shock seems to be fine, so I really don't know what else it could but I wouldn't doubt if it was just a bad rear hub bearing. I just wanna be sure I find whats wrong so I don't end up buying the wrong part.
https://ibb.co/Y01M0M3
https://ibb.co/ssKtmcG
https://ibb.co/K6Rq979
https://ibb.co/sgvvqqQ
https://ibb.co/Vps04L9
These last two show off the problem the best. The left side is fine.
https://ibb.co/8YRhHxF
https://ibb.co/17f1y1s
Old 07-19-2021, 05:41 PM   #4
bsgray2900
Exclamation
Alright so update here. I just finished replacing the wheel hub/bearing since its one whole unit together, bolted down everything back together and put the tire back on, and its still leaning. I'm at my wits end here, I have no idea what else it might be and I'm confused. I replaced both the shock and the rear wheel hub/bearing and its still leaning. I highly doubt its my spring cause its still fine. I have no idea what else it could be so anymore insight and help would be appreciated.
Old 07-19-2021, 08:51 PM   #5
that guy
Drives: 2012
Based on the photos, the entire car appears to be sitting low on the right side.
Is it parked on level ground in that photo? Do you have somewhere you can park that is level?
If on level ground, it seems to be sitting evenly, I'd wonder if the rear axle is bent.
If on level ground, it seems to still be sitting low, I'd suggest checking the rear axle mounting points, particularly the condition of the bushings to see if they are torn or separated.
that guy is offline   Reply With Quote
Old 07-19-2021, 10:18 PM   #6
bronsin
bronsin's Avatar
I would take it to a Toyota dealer And let them tell you what’s wrong. When they quote you thousands to fix it say “the car is not worth it” I’m selling it”
Then just fix it yourself
Old 07-20-2021, 12:12 AM   #7
PrincipalityOfZeon
Drives: 04 Echo 4dr HB NCP10
how are the top left and right side the top mount/trunk-H frame, trailing arm bushing/bolt, are they symmetrical.
Last edited by PrincipalityOfZeon; 07-20-2021 at 12:17 AM. Reason: trailing arm bushing/bolt
PrincipalityOfZeon is offline   Reply With Quote
Old 07-28-2021, 01:46 PM   #8
Leegamer
Leegamer's Avatar
lol, I have done similar before. Can't figure out an issue after many hours of toil, take it to a mechanic and let them figure out what it is then decline for them to fix it. Sometimes it's 100 bucks well spent.
I'm a hermit named Lee
Old 07-29-2021, 08:07 AM   #9
bronsin
bronsin's Avatar
The “the car is not worth fixing“ is also good when they try to fix 10 different things which have nothing to do with the problem. Happens a lot! Nothing like being your own mechanic!
bracket, rear, shock, strut, suspension
TRD Delrin Rear Axle Bushing Collars tmontague Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 12-15-2019 07:50 PM
Plastic "Mud Flap(?)" in Front of Rear Tire?!? MadMax General Yaris / Vitz Discussion 15 02-05-2011 10:29 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
