Old 06-29-2022, 04:13 PM   #1
sh0rtlife
unknown sensor
found a sensor behind the bumper, left front just inside the plastic air chanel guards in front of the radiator below the crash bar.....anyone know what it is for?
if only found the sensor on AC equiped cars wondering if its a radiant sensor for the condensor temp? or an outside air temp sensor?...the car has the plug for it and i grabbed the sensor off an ac car and added it..just trying to figure out exactly what i added
Old 06-30-2022, 06:20 AM   #2
BLH
Drives: 2007 Yaris Sedan
Manual shows an Ambient Temperature Sensor.
In the area you are pointing out. In the Air Conditioner section of the manual.
Old 06-30-2022, 11:30 AM   #3
sh0rtlife
hmmmmmm i kinda wondered, now is that for displaying temp or for the ac system to compensate
Old 07-01-2022, 10:27 AM   #4
BLH
Electrical diagram show it connected to the AC controller.
Since the AC controller also uses the CAN Buss to communicate with the car electronics. It may also be used to display a temperature.
trying to find downstream O2 sensor on 2012 Yaris goodmpg DIY / Maintenance / Service 4 07-22-2021 03:30 AM
Air/Fuel sensor and VSV sensor ohms reading. Misha DIY / Maintenance / Service 2 02-06-2019 05:32 PM
Rear Speed Sensor Install Help? (ABS Sensor) towerofpower DIY / Maintenance / Service 2 04-07-2014 06:32 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
