Old 07-19-2006, 10:38 PM   #1
twixt
Drives: 07 LB,04&06 ninja 636
Send a message via AIM to twixt
dynamat or cascade?
so this ebay guy states Much DYNAMAT product is asphalt based.
CASCADE Sound Damping material is vinyl based.
Vinyl based damping materials offer the following benefits:
· Equal or superior damping with lower weight.
· Less smelly off-gassing
· Molds into contours better, less need for a heat gun
· Light weight & quality adhesive reduces peeling.
http://www.cascadeaudio.com/cascadeaudio.htm
What do you think i should get?
twixt is offline   Reply With Quote
Old 07-20-2006, 06:26 AM   #2
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Don't use the Dynamat - it is asphalt based. Use the Dynamat Xtreme.
If you shop around, you can find it at steep discounts. I got mine at www.etronics.com
